    Chinese PS3 Joys won't work after update (4.0.2 -> 17-12-02)
    GamePad/GPIO/USB encoder
    chinese ps3 joys wont update
    3630
    • chamilonster
      chamilonster last edited by chamilonster
      Hi, from the begin of Recalbox, i use the official drivers and my joysticks work great, until recalbox 4.0.2
      alt text
      4.0.2 recalbox.conf:
      -------------- D1 - PS3 Controllers ------------
      #Enable PS3 controllers support
      controllers.ps3.enabled=1
      #Choose an driver between official, shanwan and gasia if you have dualshock clones (official,shanwan,gasia)
      but now, they won't work. i was try bluez, official and shanwan
      17-12-02 recalbox.conf:
      Choose a driver between bluez, official and shanwan
      bluez -> bluez 5 + kernel drivers, support official and shanwan sisaxis
      official -> sixad drivers, support official and gasia sisaxis
      shanwan -> shanwan drivers, support official and shanwan sisaxis
      i would like to make or have the old bluetooth system, i do not know, maybe i have to try deactivating the internal bluetooth?.
      Please Help me =(
        Substring @chamilonster last edited by
        @chamilonster you MUST pair again your pad, first of all. Have you done that ?
        chamilonster 1 Reply Last reply Reply Quote 0
        • chamilonster
          chamilonster @Substring last edited by chamilonster
          @substring yes man, i tried every time (put the wire 10 second on the blinking joystick), i was test it whit many joys of this kind and just nothing... als tried to pair on the "pair bluetooth joystick" on the menu but it won't be pair.
            @chamilonster pads were resetted ?
            • chamilonster
              @substring yes.. i was reset two of them
                @chamilonster i can only get some "interesting logs" when using the bluez driver, so you could eventually provide a support archive if you switch to that driver. A support archive with the original driver is also welcome.
                Before making the support archive, you must have :
                • resetted your pads
                • forgotten bt pads
                • rebooted
                • plugged the pad for 10s
                • unplugged it, and pressed the PS button
                • chamilonster
                  @substring man, how can i get the logs? i have Putty and WinSCP
                    voljega Banned @chamilonster last edited by
                    @chamilonster verify that your cable us not a power-onky cable and that it also transmits data
                      @chamilonster plug an ethernet cable, go to http://recalbox/help
                      • chamilonster
                        @substring IT WORKS!!! and for the 4 joys!! thanks you a lot man! you are the prince of the forum, metod of pair now is diferent, it was changed a little jejeje, im using the official drivers, bluez not work.
