    Overscan Issue - suggested fix and "Overscan settings (EN) update"
    overscan issue suggested fix settings
    • matrix99989
      matrix99989 last edited by matrix99989
      With the latest RecalBox image, I was having issues with a brand new install on RPi3b ignoring overscan settings (always bleeding off top and bottom) on a 720p monitor in both interface and MAME.
      Commenting out everything in boot/config.txt and adding this one line fixed it (there didn't seem to be any difference with any of the other settings I tried):
      overscan_scale=1
      I also suggest adding this to https://github.com/recalbox/recalbox-os/wiki/Overscan-settings-(EN)
      **Note that if bleeding off of top / bottom of screen only, a single setting may be used. Comment all out all other settings pertaining to overscan, and add this one setting:
      overscan_scale=1**
      Thanks,
      K
        Substring @matrix99989 last edited by
        @matrix99989 that's most of all a problem with the settings of your TV. Mine also had some overscan on 720p until I properly configured it.
