    [V3.3.0]HELP virtual gamepad
    43 54 169 edit
    7
    17
    6735
    • ionita-cristian-valentin
      ionita-cristian-valentin last edited by
      I m trying to make virtual gamepad work but when I put the command npm install I get command not found
        Hi, in recalbox, virtualgamepads is installed and running by default. You don't have anything to do... Just to connect your recalbox/smartphone to your local network. Give a look to the wiki for more informations : https://github.com/digitalLumberjack/recalbox-os/wiki/Virtual-Gamepad-(EN)
          installed latest beta but can't connect
          Unable to connect
          Firefox can't establish a connection to the server at 192.168.1.5:8080.
              The site could be temporarily unavailable or too busy. Try again in a few moments.
              If you are unable to load any pages, check your computer's network connection.
              If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web.
          it is the right ip adress i can access files through the networkexplorer but can't connect for gamepad This webpage is not available ERR_CONNECTION_REFUSED Hide details Google Chrome's connection attempt to 192.168.1.5 was rejected. The website may be down, or your network may not be properly configured.
            And if you try just your ip adress without the port number ?
              Same thing
                screen screen 1
                • digitaLumberjack
                  Hi are you on the last beta ?
                    Yes I m 🙂 just updated last night
                      It's so frustrating... I have internet connection on Pi I can ping the IP I can see the RECALBOX on the network and access the ftp files I can connect to it via SSH But I can't have virtual gamepad...
                      • mikaxii39
                        mikaxii39 last edited by
                        Hi ryuuji, We have discovered bug with a npm package during compilation of buildroot on the latest pre-release. Bug will fixed for the next release ;). PS : Sry for my english, I shouldn't sleep during my lessons ^^
                          That sounds good :). Let me know when it will be available. Will love to try it when it will be available.
                          • mikaxii39
                            There are a bug with nodejs and arm cpu too (Only pi B/B+). But all bug will be fixed for the next release (beta 8 )  😉
                              Nice. 🙂
                                FIXED it thanks to Alex Mathieu 1. Download Node (v0.12.7): http://conoroneill.net.s3.amazonaws.com/wp-content/uploads/2015/09/node-v0.12.7-linux-arm-v6.tar.gz 2. Extract the archive 3. Copy the node file ( in the bin folder of the archive ) in the system folder inside the sharing folder of Recalbox 4. Log in to Recalbox using ssh. 5. Rename the current node in node.OLD with the command mv /usr/bin/node /usr/bin/node.OLD 5. Copy the file node in the /usr/bin/ via the command: cp /recalbox/share/system/node /usr/bin/ 6. Reboot Recalbox 7. Enjoy!
                                • pdeadgaming
                                  pdeadgaming last edited by
                                  @ionita-cristian-valentin how did you get passed the [READ-ONLY] File system message?
                                    voljega Banned @pdeadgaming last edited by
                                    @pdeadgaming please read the manual and the wiki.
                                    Also don't reactivate very old threads, especially for questions already answered hundreds of time
                                      Hello
                                      Virtual gamepad included. Need use http://ip:8080 or http://recalbox:8080
                                      Please use recalbox 4.0.0
                                      101.4k
