    Move all the games and emulators from 4.0.0 to 4.1
    move 4.0.0 4.1
    2380
    • petermc
      petermc last edited by
      Hi,
      I have seen that its not possible to update from 4.0.0 beta6 (which is the version i have) to the latest version of recalbox.
      I would want to update, because my xbox one controllers has stooped working, so i think its because the controllers have been updated and i have to update the recalbox too in order to start working again.
      So, is there any easy way to install recalbox 4.1 and then move all the games and emulators i have in my actual version? (including all the images for each game). I have a big collection and i wouldnt want to add them again separately.
      Thank you.
        OyyoDams Staff @petermc last edited by
        @petermc Hi, please follow these steps:
        1. Backup your roms folder
        2. Make your new installation
        3. Restore your roms and data in roms folder
        4. Make a "quick shutdown" from Emulation Station (so it doesn't save anything)
        5. Restart Recalbox
        voljega petermc 2 Replies Last reply Reply Quote 1
          voljega Banned @OyyoDams last edited by
          @oyyodams might be a good idea to kill emulationstation between 2 and 3, not sure it is mandatory with quick shutdown, but it can't hurt.
            OyyoDams Staff @voljega last edited by
            @voljega not mandatory if you perform a quick shutdown, but yes it can't hurt 😉
            • petermc
              petermc @OyyoDams last edited by
              @oyyodams Thank you!
              1.-
              How do you restore your roms and data? Just drag and drop or copy them?
              2.-
              With that quick shutdown, do you mean, in recalbox, "quit" options, push "quick shutdown"? Or do you mean other thing?
              Thank you.
                @petermc
                1. Yes just copy all files, including downloaded_images subfolder and gamelist.xml file that are in each rom folder.
                2. Exactly 😉
                petermc 1 Reply Last reply Reply Quote 0
                • petermc
                  @oyyodams Thank you 🙂
