    ACGAM Red Spider Bluetooth Controller (AG-9055) in recalbox 4.1controller settings does not save after restart
    GamePad/GPIO/USB encoder
    acgam red spider bluetooth ag-9055
    • Leif
      Leif last edited by
      greetings from germany 🙂
      at first the hardware and software information:
      main hardware: Raspberry pi 2 B
      bluetooth dongle: CSL - V4.0 USB nano Bluetooth Adapter avec DEL Class 4.0
      OS: recalbox 4.1 with latest updates (stable)
      gamepad: ACGAM Red Spider Bluetooth Controller (AG-9055) -- similar to the Ipega PG-9055 controller?
      the situation:
      i copied the "99-joysticks-exotics.rules" from here
      (https://github.com/recalbox/recalbox-buildroot/tree/master/board/recalbox/fsoverlay/etc/udev/rules.d)
      to my
      (RECALBOX\system\udev\rules.d)
      after that, the controller was successfully paired as a gamecontroller with the mac address (aa:bb:cc:dd:ee:ff AG-9055).
      i configured the controller also successfully and completly with all buttons. then the controller function was perfectly when i defiend it at (input p1) as "#0 AG-9055" at the menu point "controller settings" .
      and now the problem:
      the controller settings will not be saved when the recalbox was shut down or restarted.
      additional information:
      in the "recalbox.conf" , the input driver was set to this:
      Set retroarch input driver (auto, udev, sdl2)
      If you don't have issues with your controllers, let auto
      global.inputdriver=sdl2
      any other options (auto or udev) make the controller not working as requested / defiend . for example in the snes emulator.
        Substring @Leif last edited by
        @leif you mean it lost the configuration done inside es ?
        Leif 1 Reply Last reply Reply Quote 0
        • Leif
          Leif @Substring last edited by
          @substring yes, if I do a reboot of the raspberry, all controller settings (configuration) are lost and I have to set up the controller again in the emulation station.
            @leif how do you shutdown your Recalbox ?
            • Leif
              @substring problem solved 🙂 after a reboot I just had to hold down the "home + x" buttons. classical user error 🙂 but, thank you for your helpfulness 🙂
              101.4k
