    One button exit and gpio
    button gpio
    • ivwshane
      ivwshane last edited by ivwshane
      According to this wiki page I should be able to specify a button for exiting emulators on recalbox. I followed the directions and used putty for Windows and logged in as root. I copied the text on this page:
      https://github.com/recalbox/recalbox-os/wiki/Enable-Gpio-button-to-close-emulator-with-only-one-button-press
      However after pasting and entering the text, I get no prompt or script that allows me to specify which button I want to use. After pressing enter I get this message:
      /recalbox/share/sys 100% [=========>] 635 --.-KB/s in 0s
      Starting button
      Then it just shows the command prompt (#).
      I'm guessing the link in the text is no longer valid?
      Any help?
      I just realized that this might be in the wrong forum.
      • lainbebop
        lainbebop last edited by
        I have the same problem 😞 @supernature2k @Substring
        Bartop Metal Slug Home Made :)
        https://forum.recalbox.com/topic/7656/my-mini-bartop-metal-slug/
        • Vanzin
          Vanzin last edited by
          I have the same problem.
          @DjLeChuck @supernature2k @Substring
          Heeeeeeeeelp us.
            Read the wiki, this only works with RA + network commands enabled. I have it working
