    Solved Anyone have a SN30, Pro?
    GamePad/GPIO/USB encoder
    anyone sn30
    6721
    • ignign0kt
      ignign0kt last edited by
      I have been having issues with pairing this controller.
      But the biggest problem is, after the controller is paired and working, when the Pi is restarted, the controller will pair/connect, but it doesn't work -- no input.
      It lists the device in bluetoothctl, and the controller indicates that it's connected, but I get nothing. Might there anything I can check to see why it's not sending input after the reboot?
      Also just wondering if I was not alone in this
        OyyoDams Staff @ignign0kt last edited by
        @ignign0kt hey,
        Can you first take a look on this page and try again by reseting your pad first ?
        Then if it still doesn't work, please connect to the web interface of Recalbox with a browser, and in the last section, make a support archive ? Then paste the link here.
        Thanks.
        ignign0kt 1 Reply Last reply Reply Quote 0
        • ignign0kt
          ignign0kt @OyyoDams last edited by
          @oyyodams hi, thanks
          The SN30 Pro does not have factory reset. Only a disconnect and force disconnect, and dedicating pairing button. I've removed and repaired it many times but the results are the same.
          I tried running the support script on the recalbox web console, but it throws an error: certificate is not yet valid
          I'm not sure what that means
            @ignign0kt "certificate is not yet valid" means you may have a network issue, and the script is unable to upload the support archive on the server.
            Here is another -manual- way:
            1. You need to connect to Recalbox with a terminal
            2. Once connected write /recalbox/scripts/recalbox-support.sh and enter
            3. Go to the save folder of Recalbox, get the recalbox-support-****.tar.gz file, upload it somewhere, and then post it.
            • ignign0kt
              ignign0kt @OyyoDams last edited by ignign0kt
              @OyyoDams
              https://nofile.io/f/D42mb5AjwQU/recalbox-support-19800101114625.tar.gz
              thanks!
              also, E4:17:D8:20:DF:DF the controller's address
                @ignign0kt First of all, are you trying to mount an external USB key or hard drive ? Because it seems there is an is an issue, Recalbox can't mount this drive.
                • ignign0kt
                  @oyyodams
                  I don't think I've ever connected a USB drive to the Pi. Just a USB bluetooth dongle that I no longer use (don't think I've plugged that in for weeks)
                  • ignign0kt
                    I saw a reddit post recommending to use the Android mode on the SN30 Pro, and that seems to resolve my issue
                      @ignign0kt Good to see it's solved. Could you be kind to post the solution that solved your issue ?
                      Also, I don"t understand why in your configuration sharedevice is on ANYEXTERNAL if you don't use any external USB drive. You should set it on INTERNAL.
                      In the archive you've sent, I can't see any clue of your controller. That's why I had doubts about a drive issue.
                      Anyway have fun 🙂
