    How to tell what snes emulator you are using?
    Emulator Arcade/PC/Console
    tell snes are
    • ivwshane
      ivwshane last edited by
      I've edited the recalbox.conf file to use snes9x as the emulator for snes on my Rpi2 but when I pull up the retroarch menu while playing a snes game at the bottom of the screen it shows it's using pocketsnes. Am I doing something wrong? snes_emulator=snes9x
        Hi did you erase the ; character at the start ? If you are using windows, try to edit the recalbox.conf file with Notepad++, or via nano with a root acces. The command will be nano nano /recalbox/share/system/recalbox.conf
        • ivwshane
          Yep, I've tried all that and it still shows pocketsnes.
          • digitaLumberjack
            What is you recalbox version ?
            • ivwshane
              On this box it's 3.2. I'll test it on 3.3 beta 2 as well, if I have the same issue I'll post it in the beta thread.
