    Odroid XU4 SYSTEM VOLUME keeps resetting to 0% instantly.
    odroid xu4 volume keeps resetting
    • MegaTimX
      MegaTimX last edited by
      Every time I try to adjust system volume in the menu, the second I leave the menu and return, it resets to 0%
      Not sure if I'm just not doing something correctly, or if it is an issue of some sort.
        But sound is ok in game, right ?
        It is an ES issue.
        MegaTimX 1 Reply Last reply Reply Quote 1
        • MegaTimX
          MegaTimX @rockaddicted last edited by
          @rockaddicted Yes, correct. Thank you. I double checked and the problem was with the wiring of my surround sound system.
            Substring @MegaTimX last edited by
            @megatimx you can't set the volume on the xu4 as it has no mixer. Plain and simple ...
            • MegaTimX
              MegaTimX @Substring last edited by
              @substring Yeah, no problem, I just wanted to keep it at max anyway. I just thought that the games had no sound since one of my cables from my TV to my sound system had become unplugged. In-app volume settings are probably only necessary on hand-held/arcade devices anyway. Thanks for the help.
