    [Resolved] Screen resolution frontend
    [resolved] resolution frontend
    • escipion
      escipion last edited by
      Hi. I want to know if i can change the resolution from the front end. I m using a 21"CRT, but the interface does not fit in the tv   Thx
      • digitaLumberjack
        Hi, you will not change the resolution but you can configure the overscan to fit with your screen. Enable overscan in the frontend (UI SETTINGS) and then edit the config.txt seek values that works with your screens : https://github.com/digitalLumberjack/recalbox-os/wiki/Edit-the-config.txt-file-(EN) https://www.raspberrypi.org/documentation/configuration/config-txt.md
        • escipion
          thx man, works perfect
