    Recalbox 171202 How to run bas files MSX?
    recalbox 171202 run bas msx
    • kelv
      kelv last edited by
      Hello
      Since last version of recalbox ,in theory, we can run bas files for msx. How can I do that? I put some bas files in the msx folder and they are not appearing. What's the procedure to run them?
      THX
      Raspberry Pi model: RPi 3b+
      Recalbox build : 7.0.1 DragonBlaze
      Hardware: MicroSD UHS 128 GB up to 80 MB, Class 10 and 2.5 A Power Supply.
      Overclocked: 1485 MHZ
      Controller(s): Wired Xbox 360 PAD (working perfectly on any other game/emulator).
      rockaddicted voljega 2 Replies Last reply Reply Quote 0
        rockaddicted @kelv last edited by
        @kelv Hi, where have you seen that .bas files are supported ?
          voljega Banned @kelv last edited by
          @kelv cas ?
          kelv 1 Reply Last reply Reply Quote 0
          • kelv
            kelv @voljega last edited by
            @voljega @rockaddicted Sorry my bad .... I read bad.... it's cas. Bluemsx: b*mped core to last version + added .cas/.m3u files support
              héhé 😉
