    DOSBOX doesn't work in 17.12.02
    Emulator Arcade/PC/Console
    dosbox doesnt 17.12.02
    4133
    • toniosj
      toniosj Spanish moderator last edited by
      On 17.12.02, the .bat archive is not called to execute the game. Anyone more with this problem?
      • toniosj
        I see that the command "mount C ........./game.pc" doesnt execute
        • toniosj
          My problem is when I use sharedevice = NETWORK, in INTERNAL works well. Im going to investigate
          • toniosj
            Definitely is a problem when Recalbox uses sharedevice = NETWORK. Dosbox doesnt detect the folders in NAS.I think that is an error.
            When I type DIR in recalbox/share, the folders of the NAS are not displayed.
            You can test it with sharedevice = NETWORK. This is my boot/recalbox-boot.conf
            sharedevice=NETWORK
            sharenetwork_smb1=ROMS@192.168.100.200:recalbox/roms:username=Antonio,password=24022001
            sharenetwork_smb2=SAVES@192.168.100.200:recalbox/saves:username=Antonio,password=24022001
            sharenetwork_smb3=BIOS@192.168.100.200:recalbox/bios:username=Antonio,password=24022001
            • toniosj
              Im testing with 17.11.10.2 and works perfectly , but with 17.12.02 not.
              Anyone can confirm?
              • toniosj
                I can confirm, that DOSBOX with sharedevice=NETWORK doesnt work in 17.12.02.
                In 17.11.10.02 was working fine, but after updating to 17.12.02 stopped working.
                voljega OyyoDams 3 Replies Last reply Reply Quote 0
                  voljega Banned @toniosj last edited by
                  @toniosj There are only a few people here using Dosbox (including me) and as far as I can tell, none of them is using a shared device on network, so your on your own there....
                    OyyoDams Staff @toniosj last edited by
                    @toniosj Hi,
                    Please take a look at your PMs.
                      @toniosj Hi,
                      Ok I've made some test. Dosbox works with the latest version with sharedevice=NETWORK.
                      I've tried the following configurations:
                      • ROMS only on NAS (so SHARE is on SD)
                      • full SHARE on NAS
                      But... In the case you've sent to me, there are some mistakes. The folder "Alone in the Dark.pc" is not correct. Please read this page: https://github.com/recalbox/recalbox-os/wiki/How-to-use-DOSBox-to-emulate-DOS-games
                      The first part of the folder name before the '.' must have equal or less than 8 characters and avoid special characters.
                      Also, no need to call jugar.bat. Just call the exe directly from dosbox.bat.
                      Hope that helps 🙂
                      toniosj 1 Reply Last reply Reply Quote 1
                      • toniosj
                        toniosj Spanish moderator @OyyoDams last edited by
                        @oyyodams Can you paste your boot/recalbox-boot.conf ?
                        Thanks!
                          @toniosj sure!
                          roms only:
                          sharedevice=NETWORK
                          sharenetwork_smb1=ROMS@192.168.1.94:Jeux/recaldev2/roms:username=recalbox,password=xxxxxxxx
                          full share:
                          sharedevice=NETWORK
                          sharenetwork_smb1=SHARE@192.168.1.94:Jeux/recaldev:username=recalbox,password=xxxxxxxx
                          toniosj 1 Reply Last reply Reply Quote 0
                          • toniosj
                            toniosj Spanish moderator @OyyoDams last edited by toniosj
                            @oyyodams I have the same configuration, but in 17.12.02 doesnt work. If I use 17.11.10.02, works fine.
                            On 17.12.02, the roms folder doesnt mount in Dosbox, but yes in the rest emulators.
