    Solved Settings are not being saved.
    settings are being saved
    9552
    • Tormentor667
      Tormentor667 last edited by
      Dear Recalbox team,
      I just installed RecalBox 17.12.02 on a completely new Raspberry Pi 3 and after booting I can't save any settings in the main menu of RecalBox. Everything I set gets lost after a reboot.
      Also noticed that the "Storage" of my SD Card (original Samsung, shipped with RBPi3) gets displayed as a red "N/A".
      Next to that my original XBOX controller seems to get mapped wrongly. All the keys have a different meaning. I would remap it but the first problem doesn't allow me to handle this. I can't use Recalbox 17.12.02 as of now 😞
      Even the webbrowser configuration doesn't work, it always says "Ein Fehler trat während des Speicherns der Konfiguration auf."
        Hello
        Samsung sdcard is bad for raspberry. It s not recommanded for recalbox.
        Use scandisk sdcard
        • Tormentor667
          Sorry for the trouble, it's a Sandisk, no idea why I wrote Samsung. It's the original Sandisk that is packaged with the Raspberry Pi 3 bundle.
          Something else I just noticed: After I connected to WiFi, I copied some romes to the /share/roms/snes folder and removed the classic Donkey Kong rom. Then I restarted the Raspberry Pi 3.
          Guess what? My roms have been deleted and the Donkey Kong Classic file has been back there even though I can definitely say I copied the other ones and removed the classic one (did it twice, just to be sure).
          It seems that booting the Recalbox always resets the whole system, even the file system. What did I wrong?!
          • Tormentor667
            Reinstall solved the problem, sorry for bothering - brilliant work on the program so far 🙂
            • proto520
              proto520 last edited by
              Hello,
              I too have the problem that neither of my settings are being saved.
              Firstly, I installed Recalbox via official Raspberry Pi Micro SD card via Wifi. When this did not work, I installed the version recalboxOS-4.1.0 manually. Both systems seem to have the issue.
              With both versions, I configured a USB fight stick controller and the Wifi settings via keyboard. Upon restarting the Pi, all settings I made seems to be reset.
              Does anyone know, what I can do?
              proto520 1 Reply Last reply Reply Quote 0
              • proto520
                proto520 @proto520 last edited by
                I didn't quite manage to fix the issue, but at least to overcome it. Let me explain: originally, I downloaded the Recalbox OS v4.1.0 from https://github.com/recalbox/recalbox-os/releases/tag/4.1.0 This version has the issue with not being able to save the settings. This version is installed by simply copying a bunch of files to the SD card and letting the RPi boot.
                But then, I discovered the version 17.12.02 of Recalbox, that I downloaded from https://archive.recalbox.com This is an image (img.xz) file, that I installed using the Etcher software (as mentioned on the download page) on the SD card. This version of Recalbox seems to do the trick and I was able to enter several settings that were still set after rebooting the RPi.
                I hope, this helps everyone with the same problem.
