    msx problema
    Emulator Arcade/PC/Console
    msx problema
    5440
    • КАМИЛЬ СУЛТАНОВ
      КАМИЛЬ СУЛТАНОВ last edited by
      После обновления не работает msx игры не включаются.там был эмулятор fmx его больше нет а на bluemsx он вообще не работает.пожалуйста исправьте эту проблему в будущих обновлениях
        OyyoDams Staff @КАМИЛЬ СУЛТАНОВ last edited by
        @камиль-султанов Hi,
        You should try to speak english to get help 🙂
        КАМИЛЬ СУЛТАНОВ 1 Reply Last reply Reply Quote 0
        • КАМИЛЬ СУЛТАНОВ
          КАМИЛЬ СУЛТАНОВ @OyyoDams last edited by
          @oyyodams After I updated Recalbox from 4.0 to 4.1, MSX doesn't work. There's no FMSX in the settings. I want this error to be corrected in future updates. There's only BLUEMSX, but the games don't work. I hope you understand
          • falconx62
            falconx62 last edited by falconx62
            Hello, Bluemsx doesn't work with bios msx like Recalbox 4.0.
            You must download bluemsx on your computer (PC,...) and you copy the files "machines" and "databases" and paste them in your recalbox file bios.
            Hope it's help!
            P.S.: a link who explain it
            <iframe width="1903" height="764" src="https://www.youtube.com/embed/FneSAV1pLyE" frameborder="0" gesture="media" allow="encrypted-media" allowfullscreen></iframe>
            • КАМИЛЬ СУЛТАНОВ
              КАМИЛЬ СУЛТАНОВ @falconx62 last edited by
              @falconx62 Thanks for your good friend. But Smozhe to help me with ColecoVision he doesn't work at all. also Magnavox Oddyssey 2. I've tried different ROMs, but nothing works
              • falconx62
                Bluemsx emulate Colecovision too.
                Sorry for the Oddyssey 2 but I don't use it.
                I'll check if I've the the time 😉
                • falconx62
                  For the oddyssey 2, you need the bios o2rom.bin.
                  You put it in the bios file and it works.
                  But you need a keyboard to lauch some games and I tried Frogger and can't manage to move...
                  • КАМИЛЬ СУЛТАНОВ
                    @falconx62 Thank you so much. And you're playing the Famicom Disk System. I tried to play in vs Excitebike. I turned on the VS mode and the Set side B label is not
                    • falconx62
                      Sorry, I can't help for the family disk system. There 's a version of vs exitebike playable with mame but it's not the same...
                      • falconx62
                        As I'm curious and that I love exitebike I've checked a little more and find the solution.
                        I've placed the bios "disksys.rom" in the bios file and exitebike in the rom file "fds".
                        When the game ask to set the b side you press the buttons L and R (LB and RB on an xbox 360 pad) and it's works.
                        Enjoy ;)!!!
                          voljega Banned @falconx62 last edited by
                          @falconx62 you don't even need to press both, it's one of the two (I never manage to remember which one), it's just take a few seconds to be taken into account by the emulator
                          • falconx62
                            @voljega Merci pour l'info!
                            • falconx62
                              @КАМИЛЬ-СУЛТАНОВ @voljega It's the L button!
                                @falconx62 thanks ! but I think by the end of the month I will have forgotten again 😛
                                • КАМИЛЬ СУЛТАНОВ
                                  КАМИЛЬ СУЛТАНОВ @voljega last edited by
                                  @voljega thanks
                                  • Albcatmastercat
                                    Albcatmastercat last edited by
                                    https://forum.recalbox.com/topic/11823/msx-games-won-t-run-at-all/3 I'm coming from this thread (thought it'd be better to go to a larger topic on the matter).
                                    I did what you guys/gals suggested, but the games still won't run. Is there anything I might have missed?
