    Screen burn on a 5 inch HDMI
    inch hdmi
    • username
      username last edited by
      I bought this 5" display and have it configured mostly OK. One thing I've noticed is there is a very noticeable image 'burn' when it's been on a certain screen for a while. It doesn't even have to be very long - even 30 seconds on a menu and there will be a faint outline of it once closed.
      It always disappears eventually but it's very distracting. I know it can't be real screen burn like on the old monitors we used to use.
      Has anyone else experienced this? Do you think I have a faulty unit or is it a known issue? Is there any setting I could change that might help?
        voljega Banned @username last edited by
        @username yeah I have a 7' HDMI screen and it does the same thing... cheap quality I guess
        • Tepoo
          Tepoo last edited by
          Normal behaviour when the screen has a low quality and creates to much temp.
          You have 3 possible ways
          1. buy one which has a better quality
          2. deal with it
          3. find a solution to compensate the temp.
          Kind regards
          Tepoo
