    Hyperion + LED APA102
    GamePad/GPIO/USB encoder
    hyperion led apa102
    • tino
      tino last edited by
      Hello Recalboxers,
      I want to add some ambilight to my recalbox. I use the APA102 LEDs and set it up like this (from the hyperion tutorial):
      Sketch
      Unfortunately it doesn't work. Now im searching for the problem.
      I checked the wiring a view times and couldn't find a mistake.
      Maybe I made a mistake when setting up Recalbox for Hyperion. This is what i've done so far:
      • update to recalbox 17.11.10.2
      • copy my hyperion.config.json to /recalbox/share/system/config/hyperion/hyperion.config.json
      • enable hyperion in recalbox.conf
      3/4 of the LED stripe lights up when starting the Pi. But then the LEDs do nothing. Seems to me like the LEDs don't get a signal from the DI / CI GPIOs. When I checked the Hyperion status via ssh I get the following Error:
      Does anyone have an idea what the problem might be?
      Thanks
        Hello @tino
        @digitalLumberjack or @digitalLumberjack may help you
        • digitaLumberjack
          Hi,
          could you add the line dtparam=spi=on in your config.txt file please:
          mount -o remount,rw /boot && echo 'dtparam=spi=on' >> /boot/config.txt
          and reboot
