    Testers wanted: Squashfs
    Testers's corner
    testers wanted squashfs
      REMINDER
      make sure you read and understand what we expect from testers
      So what now?
      branch: https://review-subs-test-d1jlnb-archive-review-prod.recalbox.com
      Goal: make recalbox like a firmware, make updates much faster, make recalbox more robust
      Archs: Pi3 only for now. x86_64 should come shortly
      A squashfs file is like a read only image file that can be mounted like any device. Part of it is in memory.
      Steps to update and test - Pi3 only for now
      1. Update to the mentionned branch (i mean do update, not juste change the update type)
      2. Once the update is done:
      mount -o remount, rw /boot
      echo "boot=squashfs" >> /boot/recalbox-boot.conf
      /recalbox/scripts/upgrade/recalbox-upgrade.sh upgrade && reboot
      From here, Recalbox will download a squashfs, copy it on first reboot with the usual upgrade progress bar, and transparently finish the update on the following reboot.
      To make sure everything happened as expected :
      • dmesg | grep irfs should be quite self explanatory
      • mount | grep overlay should return a single line
      Expected test cases
      There are many cases that need to be tested, here are a few independant scenarios :
      • your Recalbox still boots with NOOBS
      • you have a USB key/hard drive
      • you upgraded from a 4.0.x version to 4.1 (or later)
      • you installed Recalbox with the .img
      Please report your environment as I need to make sure all cases are covered, and mostly that the update doesn't break anything.
      OyyoDams 1 Reply Last reply Reply Quote 1
        OyyoDams Staff @Substring last edited by
        @substring Ok so here is my result.
        1. Starting from 17.11.02 stable. Download of update from branch: OK
        2. Auto upgrade after reboot: OK
        3. recalbox-boot.conf trick and command-line download of update: OK
        4. Auto upgrade after reboot with "upgrading the squashfs" message: OK
        5. Final reboot: OK, Recalbox works as expected.
        BUT...
        # dmesg | grep irfs
        [    1.605723] (RECALBOX-irfs) Starting new boot log
        [    1.619000] (RECALBOX-irfs) Mounted: /dev/mmcblk0p2 as root source, booting to  default
        [    1.621327] (RECALBOX-irfs) UPGRADE: found /new_root/defaultroot/recalbox.squashfs.upgrade
        [    1.622274] (RECALBOX-irfs) Checking kernels ...
        [    1.623184] (RECALBOX-irfs) Couldn't find a squashfs file, or squashfs boot is not set, defaulting to SD
        [    1.624108] (RECALBOX-irfs) Kernels OK (zImage and zImage.sd) ! Continuing ...
        [    1.624185] (RECALBOX-irfs) Trying to use root from:
        [    1.625080] (RECALBOX-irfs) Couldn't mount a squashfs
        [    1.625144] (RECALBOX-irfs) Remounting to the default root device
        So there is an issue somewhere.
        For information, here is my /boot/recalbox-boot.conf:
        # more /boot/recalbox-boot.conf
        sharedevice=NETWORK
        sharenetwork_smb1=ROMS@192.168.1.94:Jeux/Recalbox/roms:username=recalbox,password=@@@@@@
        sharenetwork_smb2=SAVES@192.168.1.94:Jeux/Recalbox/saves:username=recalbox,password=@@@@@@
        boot=squashfs
          Substring @OyyoDams last edited by
          @oyyodams can you get /boot/boot.log please ?
            @substring I have no boot.log file.
            For information:
            # df
            Filesystem           1K-blocks      Used Available Use% Mounted on
            none                    242132         0    242132   0% /dev
            /dev/mmcblk0p2         1874516   1240820    535137  70% /
            tmpfs                   246692         0    246692   0% /dev/shm
            tmpfs                   246692        20    246672   0% /tmp
            tmpfs                   246692      2992    243700   1% /var
            tmpfs                   246692        92    246600   0% /run
            /dev/mmcblk0p1           64511     11817     52694  18% /boot
            /dev/mmcblk0p3        13257232    913612  11647148   7% /recalbox/share
            • nwildner
              nwildner last edited by
              Out of curiosity: Does this squashfs feature will work somehow like a switch firmware in the future, having 2 "base images" and booting the newest one or the backup if the user wants to change it? Example:
              SWDEP_02# show bootvar
              Image  Filename   Version     Date                    Status
              1      image-1    2.0.0.66    09-Mar-2017  13:23:09   Active*
              2      image-2    2.0.0.42    01-Sep-2010  15:26:19   Not active
              "*" designates that the image was selected for the next boot
              PT_BR Retrogaming on Telegram
