    Sound issues
    sound issue driver
    3884
    • Javier Sandoval
      Javier Sandoval last edited by
      I wonder, im using recalbox pc x64 and so far i tested in 2 diferent computers, and it works great, the first one i was using an nvidia card with hdmi, so i though that was the problem for my sound issue, the problem is, when i set up the audio, i only have 2 options, auto and "realtex,hd,hdmi1,hdmi blabla bla" so on that particular computer, setting up to auto i get sound but i cant control the sound volume, now on the current computer im using, it has onboard intel hdmi outlet, and on the sound menu, i get 4 diferent options, out of those 4, i only get sound in one of them. The issue is, i cant control the sound either, it stays at 0 no matter what i choose. So i wonder if theres something i can do to make it work normal, so i can control the sound from the computer. Im using a hp pro desk 600 g1 ssf. Thanks for any help.
        Substring @Javier Sandoval last edited by
        @javier-sandoval we'll have a more in-depths look at volume on PC some day.
        Fror now, just SSH, type TERM=xterm alsamixer and play around with your volumes using your keyboard
        • Javier Sandoval
          thanks for the fast reply, i really dont ssh as is my only computer, its there a way i can do that from the OS itself?
          Substring voljega 2 Replies Last reply Reply Quote 0
            @javier-sandoval nope sir 😕
            • Xanarkan
              Xanarkan last edited by
              If you are on Windows 10 you can just open a Ubuntu console and connect to SSH to your PC with "ssh root@xx.xx.xx.xx" and then the default password.
              Raspberry Pi 3b @1.3 GHz | Xbox 360 Controllers | Recalbox 4.1
              HTPC: Intel Core i5 4570S @2.9 GHz | Intel HD Graphic 4600 | Kingston KHX1600C9D3 4 Go DDR3 | Asus H81M-PLUS | Asus Xonar DX
                voljega Banned @Javier Sandoval last edited by
                @javier-sandoval you can try to connect a keyboard, exit Emulation Station with F4 et then launch a terminal by alt+F4
