    [4.1 X86] Problem with DC, Gamecube, wii
    Emulator Arcade/PC/Console
    3423
    • xtreemsurf
      xtreemsurf @leok last edited by xtreemsurf
      @leok
      Sorry to drag up an old topic...
      I'm having the same exact problem with D.C. & Wii/GC not loading on 4.1 stable x86. It kicks me right back to the menu. Did you ever find a fix for this or at least find a list of compatible GPUs?
      Thanks!!
        Hello @xtreemsurf
        please dont up old post, split you message.
        @rockaddicted do you test with emulators on x86 ?
          work fine on my setup.
          I need more informations about hardware.
          xtreemsurf 1 Reply Last reply Reply Quote 0
          • xtreemsurf
            xtreemsurf @rockaddicted last edited by
            @rockaddicted
            Thanks for the replies!
            I've tried this on a Dell Studio w/ Intel Core 2 Quad, a Gateway w/ Intel Core i3, and an ASUS laptop with Intel Core i3. All of these were running the onboard video card, but only the ASUS would load D.C. & GC games. N64 runs perfectly on all 3 systems. Do you have any recommendations for an add-on video card that will work with D.C. & GC games? Thanks again!
              There is no complete hardware list. If GPU is not one of the last generation, it should be supported.
              About DC and GC/WII emulation, you need an OpenGL 3.1 min support.
              https://github.com/recalbox/recalbox-os/wiki/Board-Compatibility-(EN)
              rockaddicted xtreemsurf 2 Replies Last reply Reply Quote 0
                rockaddicted @rockaddicted last edited by
                you can find a compatibility list here, but it is a new one, so there is not a lot of informations:
                • xtreemsurf
                  @rockaddicted
                  Thanks for the advice! I'm looking for a budget card... either a GeoForce GT 710 or Radeon HD 6450. Does Recalbox tend to work better with an Nvidia card or an AMD card? Thanks again!
