    External USB-WiFi Dongle TP-Link TL-WN822N not working
    external usb-wifi dongle tp-link tl-wn822n
    • RK.aus.S
      RK.aus.S last edited by RK.aus.S
      Hello
      I use Recalbox v4.10 on a RPi3. I bought a TP-Link TL-WN822N USB Wifi adapter, since it is listed in the compatibility matrix, but it does not work. It seams like no driver is loaded in Recalbox since the LED on the Wifi adpater never lights up.
      I have the internal (on board) Wifi adapter blacklisted like described.
      I'm not a Linux guru, so I hope someone can help me.
      Here the output of dmesg:
      [ 1.997721] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
      [ 2.098231] usb 1-1.3: New USB device found, idVendor=2357, idProduct=0108
      [ 2.098246] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [ 2.098252] usb 1-1.3: Product: 802.11n NIC
      [ 2.098258] usb 1-1.3: Manufacturer: Realtek
      [ 2.098265] usb 1-1.3: SerialNumber: 00e04c000001
      This is the output of ifconfig:
      eth0 Link encap:Ethernet HWaddr B8:27:EB:F2:08:15
      inet addr:192.168.1.67 Bcast:192.168.1.255 Mask:255.255.255.0
      inet6 addr: 2a02:1205:34c9:ec10:ba27:ebff:fef2:815/64 Scope:Global
      inet6 addr: fe80::ba27:ebff:fef2:815/64 Scope:Link
      UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
      RX packets:17962 errors:0 dropped:10422 overruns:0 frame:0
      TX packets:3164 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:1000
      RX bytes:3915583 (3.7 MiB) TX bytes:413516 (403.8 KiB)
      lo Link encap:Local Loopback
      inet addr:127.0.0.1 Mask:255.0.0.0
      inet6 addr: ::1/128 Scope:Host
      UP LOOPBACK RUNNING MTU:65536 Metric:1
      RX packets:34 errors:0 dropped:0 overruns:0 frame:0
      TX packets:34 errors:0 dropped:0 overruns:0 carrier:0
      RX bytes:3157 (3.0 KiB) TX bytes:3157 (3.0 KiB)
      No Wifi adapter shows up?
      There are several posts around having trouble with other TP-Link adapters, like the WN823N. They somehow come to the conclusion that there seams to be something wrong with the driver and its Vendor- or ProductID (idVendor=2357, idProduct=0108).
      I choosed this Wifi adapter because a weak signal from my Wifi access point. I got other Wifi adapters running (e.g. Edimax EW-7811UN) but I hoped to get more troughput with the new TP-Link dongle...
      Hope anyone can help me trough here?
      Would be very graceful.
      Regards
      Roman
      Sorry for my english, it not my mother language. 😕
      100.7k
