    Activate VICE C16 and PLUS/4 emulator
    Emulator Arcade/PC/Console
    activate vice c16 plus4
    7339
    • C16-fan
      C16-fan last edited by
      Hello,
      I would like to use the C16 PLUS/4 emulator with Recalbox. Is it possible to activate?
      Today the C64 emulator is available and sharing the same "vice3.0-libretro" so above emulator shall be quite easy to add (for someone knowing how to do it...I know nothing about linux and coding/compiling).
      Thank you for your help!
        rockaddicted @C16-fan last edited by
        @c16-fan
        Vice emulator manage these hardware but I don't see your C16 :
        The following programs are included:
        x64, a C64 emulator;
        x64sc, a C64 emulator focused on accuracy;
        xscpu64, a C64 emulator with a SuperCPU cart;
        x64dtv, a C64 Direct-to-TV (DTV) emulator;
        x128, a C128 emulator;
        xvic, a VIC20 emulator;
        xpet, a PET emulator;
        xplus4, a PLUS4 emulator;
        xcbm2, a CBM-6x0/7x0 emulator;
        xcbm5x0, a CBM-5x0 emulator;
        vsid, a SID player;
        c1541, a stand-alone disk image maintenance utility;
        petcat, a CBM BASIC de-tokenizer;
        cartconv, a C64/C128 cartridge conversion program.
        • C16-fan
          C16-fan last edited by C16-fan
          Hello rockaddicted,
          Actually C16 is emulated through PLUS4 (xplus4). It is just a matter of memory and kernal version. When I use VICE on Windows I need to launch xplus4 then select C16 mode :
          text alternatif
            @c16-fan ok
            And what is the difference with x64 vice binary ?
            I really don't know these hardwares ...
            • C16-fan
              x64 is for emulating the Commodore 64 which has been sold some years before PLUS/4 (and C16). These models had a different CPU and video chip. Mostly the C16 was more or less the replacer of the VIC-20 while PLUS/4 was trying to replace the C64.
              C16 and PLUS/4 have the same architecture that's why the same core is emulating them.
              The C16 had a quite good success in some countries while unknown to others.
                ok thank you for explanations.
                and those 2 systems had some specifics games ? not existing on C64 ?
                • C16-fan
                  Yes games for C64 cannot run on PLUS/4 or C16 and vice-versa.
                  Games for C16 runs on PLUS/4 while the opposite may be true if C16 has a memory expansion.
                    @c16-fan ok, I'll have to check the libretro core makefile. But I think we will have to build differents binaries, for each version of commodore.
                    If we do that, we'll add it as C64 cores. That could be managed by ES options.
                    I don't want to add a specific system to each commodore version. That will be a f**king pain to maintains themes.
                    • C16-fan
                      That would be great!
                      Actually in VICE menu it is possible to select the core so having the possibility to add other ones will be perfect!
                      Just to know (and while this is added to new release of Recalbox) is there a way for me to test already this core (xplus4 instead of x64)? Is it only a matter of replacing some files or is it more complex? This is only for a test so even if the frontent still shows C64 I don't care.
                        @c16-fan once I'll do a build test, I'll tell you and tell you how to upgrade on this branch test
                        • C16-fan
                          Sure 🙂
                            Substring @rockaddicted last edited by
                            @rockaddicted or switch back to vice ...
                            • RustyMG
                              RustyMG last edited by
                              @rockaddicted Hi, was this ever resolved?
                              Thanks.
                              Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
                                rockaddicted @RustyMG last edited by
                                @rustymg no free time to work on this point.
                                101.4k
