    Changing GPIO pins used for shutdown
    GamePad/GPIO/USB encoder
    changing gpio pins used
    • Matra
      Matra last edited by
      Is there a config or anything anywhere that will allow me to choose the pins used for
      "system.power.switch=PIN56ONOFF"
      Pin 5 is used by the SPI CLK and that is being used on my screen... I want to add a way of turning it on/off with a gameboy power switch but unknown as to whether I need to recompile stuff or if there is a simple config where I can change it (as I haven't found it yet through exploring!!)
        Hi you will have to change the script managing that :
        https://gitlab.com/recalbox/recalbox/blob/master/board/recalbox/fsoverlay/recalbox/scripts/rpi-pin56-power.py
        on your recalbox /recalbox/scripts/rpi-pin56-power.py
        Matra 1 Reply Last reply Reply Quote 1
        • Matra
          Matra @rockaddicted last edited by
          @rockaddicted thanks, I'll have a look 🙂
