    4.1 permission folders
    2937
    • gothrek
      gothrek last edited by
      Hi, i try to copy some files (like 4.02) from pc to roms folder \ip\share\roms
      i stop the ES but when i try to overwrite the files i receive a permission error message.
      any ideas?
      akh150 abunille 2 Replies Last reply Reply Quote 0
      • akh150
        akh150 @gothrek last edited by akh150
        @gothrek seems weird, there is no need to turn off ES to copy roms in the folder. Try without stopping ES.
        Upvote si je t'ai aidé 😉
        gothrek 1 Reply Last reply Reply Quote 0
        • gothrek
          gothrek @akh150 last edited by
          @akh150 are u sure? before without stopping ES, the recalbox system dont found new roms/images.
          • abunille
            abunille @gothrek last edited by abunille
            @gothrek
            On which Hardware is Recalbox installed?
            Copy to roms works (means only problems with overwriting)?
            Same Problem when going over Webmanager?
            • gothrek
              gothrek @abunille last edited by
              @abunille Hi, i try with web, but there are a very lot i prefer with shell.
              i use a PI3, and i have this prob only when overwriting (i upgrade from 4.02)
              • akh150
                @gothrek sure. Once your roms are on your pi, just restart it. Do you use a usb key ? Or only your sd card ?
                • abunille
                  @gothrek
                  Deleting the file works?
                  Have you an external device (ntfs maybe) as storage?
                  At the moment i dont know what is the problem.
                  • gothrek
                    @abunille i reinstall all from zero. now its all ok. i dont understand why.
                    tks
                    • abunille
                      @gothrek
                      strange, but if it works now, it's good 😉
                      Please mark it as solved:
                      Topic Tools -> Ask a question + Topic Tools -> Mark as Solved
                      101.0k
