    Combination GPIO & USB
    GamePad/GPIO/USB encoder
    combination gpio usb
    5011
    • sigmatec
      sigmatec last edited by
      Hi, I would like to know if it is possible to combine the GPIO and a No delay board?
      I want to put 8 buttons instead of 6 and notice the gpio has 13 inputs for each player not enough for the for the 8 buttons layout.
      So to solve this can I put a external single board to map the rest of the buttons?
      This image is to help to understand what is my idea.
      alt text
      Thanks in advance
        voljega Banned @sigmatec last edited by
        @sigmatec no you can't, you can't combine two boards for one controller.
        The best way is to fing a supported usb controller supportingvenough buttons (like some Xin-Mo 1-player)
        sigmatec 1 Reply Last reply Reply Quote 0
        • sigmatec
          sigmatec @voljega last edited by
          @voljega said in Combination GPIO & USB:
          Xin-Mo 1-player
          Xin-Mo is the best quality board?
          • Dragu
            Dragu Banned last edited by
            @sigmatec said in Combination GPIO & USB:
            No delay board
            No delay, I dont know. Can it be a zero delay board (Dragonrise) ?
            With zero delay you can connect up to 12 buttons without the 4 function keys also on board (turbo, autofire, clear, mode)
              @sigmatec I never said that.
              • sigmatec
                @voljega Can I combinane a Xin-Mo 2 Player with GPIO?
                  @sigmatec if you say 3 player (2 on xinmo and one on gpio) yes, if you mean mixed buttons between xinmos and gpio, no
                  • sigmatec
                    sigmatec @voljega last edited by sigmatec
                    @voljega By the way if I'm using the mk_arcade_joystick_rpi I can't use the shutdown script that uses the pin 5 & 6.
                    Is possible to make that command executed by a button from the zero delay board? I know there's a combo to go to the shutdown menu but I would like a more direct approach without the combos (kids proof).
                    • Dragu
                      @sigmatec
                      I dont know why people need a script to shutdown recalbox. There are minimum 3 other ways. First, if you push during ES select button, you arrive in the restart, shutdown menu.
                      If you have Recalbox Manager installed on a nearby PC, you can use for shutdown of system or just restart from ES.
                      Most games that hangs, can be leaved with hotkeys, in dosbox with Ctrl+F9.
                      If you really dont get out, there are 2 unused pinholes near the GPIO. With text "Run". If you solder pins/cable to a button, closing the button is reset.
                      I was never needing something else.
                      • sigmatec
                        sigmatec @Dragu last edited by
                        @dragu I think with the reset button I can corrupt the sd card.
                        • Dragu
                          @sigmatec
                          Excuse, but the connection on the 2 RUN Pins is a Soft Reset Switch.
                          So not the same as you pull the plug. You can find sources on the web for this.
