    Add new Shadersets is possible?
    shadersets possible
    2623
    • amzg
      amzg last edited by
      Hi!
      There are this available sets, scanlines/retro/none (/recalbox/share_init/system/configs/shadersets).
      Is possible to add new custom Shadersets ??? how??
      I try to put a new custom file.cfg, but the new shaderset doesn't appear in the EmulationStation menu "GAME SETTINGS".
      thanx
      • amzg
        amzg last edited by
        Isn't possible? 😢
          Hello @amzg
          May be help
          https://github.com/recalbox/recalbox-os/wiki/Shaders-configuration-(EN)
          amzg 1 Reply Last reply Reply Quote 0
          • amzg
            amzg @acris last edited by amzg
            hello @acris!!
            I ask if I can add more shadersets in EmulationStation menu, besides the default ones. The wiki does not clarify anything
            thank!!
              voljega Banned @amzg last edited by
              @amzg if they are in the right format yes you can
              • amzg
                amzg @voljega last edited by amzg
                @voljega said in Add new Shadersets is possible?:
                Thank!
                Can you explain more, in what directory should the files go? With doubling the retro.cfg and changing it would ?
                • amzg
                  amzg last edited by
                  I give up, I can not 😞
