    Problem with scraper
    scraper
    4291
    • HotRod
      HotRod last edited by
      Hi,
      Since the I updated my recalbox to 4.1 I been having problems scraping games, now when I select the data base, the specific system and hit start I get the following message:
      "WE CAN'T FIND ANY SYSTEM! CHECK THAT YOUR PATHS ARE CORRECT IN THE SYSTEM CONFIGURATION FILE, AND YOUR GAME DIRECTORY HAS AT LEAST ONE GAME WITH THE CORRECT EXTENSION"
      any help?
        Hello @HotRod
        scrap with recalbox and screenscraper ? system ?
        • HotRod
          yes, I scrap with recalbox and screenscraper and I tried selecting all systems and individual also 😕
          • Maldorhan
            Maldorhan last edited by
            Change "only missing images" by "all games" (or something like that), this message "cant find any system" happens when your games all already have images, even if it's not the same ones as the scraper.
            RPi0W / Retroflag GPi CASE
            RPi3B+ / Retroflag SUPERPi CASE-J
            Retroflag NESPi CASE v1
            • HotRod
              this is frustrating, I format my sd card and install recalbox 4.0 and I can sprap my games with no problem, update to 4.1 and have the same message. My last move was to install the recalbox 4.1 image straight to the sd card with Etcher but still have the same problem when I want to scrap my new roms with the recalbox scraper. By the way I tried with 3 sd cards.
              • Moon
                Moon last edited by
                Got a similar issue here. I scrape using UXS in the meantime.
                I remember that the scraping from screenscraper on recalbox worked properly on the day I updated to 4.1, but it doesn't work now, and I cant seem to figure out why.
