    Recalbox 4.1 x64 stable on PC : is there a way to see if the onboard bluetooth is supported ?
    recalbox 4.1 x64 stable onboard
    13159
    • Maldorhan
      Maldorhan last edited by
      Hi,
      I know that the new Recalbox 4.1 adds support for bluetooth internal board of the Rpi3, on top of many bluetooth dongles, but on my side i'm using a PC Intel NUC with onboard wifi and blutooth. The wifi is supported fine by recalbox, out of the box, but I have no idea about the integrated bluetooth chip, when I try to pair a controller it loads and then says "no controller found" but that's it.
      How do I know if the integrated bluetooth is supported and is there a list of supported ones ? Else I guess I got to buy a bluetooth dongle as we did before...
      NUC bluetooth chip is : Intel® Wireless-AC 8265 + BT 4.2 (last gen bluetooth)
      Thanks for your answers 🙂
      RPi0W / Retroflag GPi CASE
      RPi3B+ / Retroflag SUPERPi CASE-J
      Retroflag NESPi CASE v1
        Substring @Maldorhan last edited by
        @maldorhan yup, SSH to the box or open a local terminal and type hciconfig
        • Maldorhan
          Maldorhan last edited by Maldorhan
          @substring said in Recalbox 4.1 x64 stable on PC : is there a way to see if the onboard bluetooth is supported ?:
          hciconfig
          Wow fastest answer ever ! 🙂
          I got this :
          /boot$ hciconfig
          hci0: Type: BR/EDR Bus: USB
          BD Address: 00:00:00:00:00:00 ACL MTU: 0:0 SCO MTU: 0:0
          DOWN
          RX bytes:86 acl:0 sco:0 events:4 errors:0
          TX bytes:12 acl:0 sco:0 commands:4 errors:0
          Edit : so I guess it's not supported ?
          • Maldorhan
            (Since there's no address right ?)
              @maldorhan could be a simple firmware problem. Do you know the BT chipset ? if not can you find it in dmesg ? or, with your pi plugged, go to http://recalbox/help and generate a support archive 🙂
              • Maldorhan
                Here's what I found in dmesg : (if I read the right part ?)
                [ 1.786196] e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC clock
                [ 1.837669] usb 1-8: New USB device found, idVendor=8087, idProduct=0a2b
                [ 1.837671] usb 1-8: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                [ 1.844536] usbcore: registered new interface driver btusb
                [ 1.845402] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
                [ 1.846407] Bluetooth: hci0: Device revision is 16
                [ 1.846408] Bluetooth: hci0: Secure boot is enabled
                [ 1.846409] Bluetooth: hci0: OTP lock is enabled
                [ 1.846409] Bluetooth: hci0: API lock is enabled
                [ 1.846410] Bluetooth: hci0: Debug lock is disabled
                [ 1.846411] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
                [ 1.846755] bluetooth hci0: Direct firmware load for intel/ibt-12-16.sfi failed with error -2
                [ 1.846761] Bluetooth: hci0: Failed to load Intel firmware file (-2)
                [ 1.847516] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
                [ 1.848220] usbcore: registered new interface driver usbhid
                [ 1.848222] usbhid: USB HID core driver
                [ 1.848433] Bluetooth: hci0: Device revision is 16
                [ 1.848434] Bluetooth: hci0: Secure boot is enabled
                [ 1.848434] Bluetooth: hci0: OTP lock is enabled
                [ 1.848435] Bluetooth: hci0: API lock is enabled
                [ 1.848435] Bluetooth: hci0: Debug lock is disabled
                [ 1.848436] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
                [ 1.848443] bluetooth hci0: Direct firmware load for intel/ibt-12-16.sfi failed with error -2
                [ 1.848444] Bluetooth: hci0: Failed to load Intel firmware file (-2)
                [ 1.870989] e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) f4:4d:30:6c:89:9c
                [ 1.870991] e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
                  @maldorhan Bull's eye ! looks like we're missing that driver for now
                  Maldorhan 1 Reply Last reply Reply Quote 0
                  • Maldorhan
                    Maldorhan @Substring last edited by
                    @substring Well, I'll just wait for it to be integrated (maybe?) in future releases and go buy a random generic bluetooth dongle for now I guess 😄 Thanks a lot for your help anyway !
                      the file is available at https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/intel
                      No idea yet where to drop it ... /lib/firmware/intel ? or /etc/firmware/intel ? No recalbox at hand for now.
                      But i think we can make it available by default in a later release
                      • Maldorhan
                        Maldorhan @Substring last edited by Maldorhan
                        @substring Oh wow thanks ! I answered before I saw your second answer, i'm gonna check if I can add it manually (I have no clue about that yet), and else wait for an update, thanks A LOT for considering it and again for your help !
                          @maldorhan Once I get back home i'll have a quick look where the file is suppoed to be. I don't know if you're familiar with linux, but it may not be a funny moment for you to drop the file where it is expected. I'll give you the step-by-step if necessary
                          • Maldorhan
                            I have honestly no idea where to put it yet even if I know a bit of Linux but I'll make sure to look hard for it and if needed follow your (very much appreciated) advices when you get home
                            • Maldorhan
                              Seems to be /lib/firmware/intel doesn't work for now though
                              • Maldorhan
                                @Substring
                                I get that after adding the files
                                Bluetooth: hci0: Found device firmware: intel/ibt-12-16.sfi
                                [ 1.858988] Bluetooth: hci0: Failed to send firmware signature (-38)
                                Edit : this the the new message I get in dmesg, no idea how to bypass? the signature check or add one
                                  @maldorhan I'm still looking for, but anyway, keep checking with hciconfig because the firmware upload happens wuite early in the boot process, might need bluez to be started too
                                  • Maldorhan
                                    @Substring hciconfig still the same for now, dmesg fails because of this "fail to send firmware signature" error now so it finds the firmware but doesnt load it up for some reason, I have no idea what's this signature sending error is about, still googling it with no results yet, I'll try to reboot and wait a bit more
                                    • Maldorhan
                                      /lib/firmware/intel$ dmesg | grep Bluetooth
                                      [ 1.476560] Bluetooth: Core ver 2.21
                                      [ 1.476569] Bluetooth: HCI device and connection manager initialized
                                      [ 1.476572] Bluetooth: HCI socket layer initialized
                                      [ 1.476574] Bluetooth: L2CAP socket layer initialized
                                      [ 1.476585] Bluetooth: SCO socket layer initialized
                                      [ 1.493970] Bluetooth: HCI UART driver ver 2.3
                                      [ 1.493972] Bluetooth: HCI UART protocol H4 registered
                                      [ 1.493972] Bluetooth: HCI UART protocol BCSP registered
                                      [ 1.493973] Bluetooth: HCI UART protocol LL registered
                                      [ 1.493974] Bluetooth: HCI UART protocol ATH3K registered
                                      [ 1.493975] Bluetooth: HCI UART protocol Three-wire (H5) registered
                                      [ 1.493999] Bluetooth: HCI UART protocol Intel registered
                                      [ 1.494011] Bluetooth: HCI UART protocol BCM registered
                                      [ 1.494012] Bluetooth: HCI UART protocol QCA registered
                                      [ 1.846754] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
                                      [ 1.847769] Bluetooth: hci0: Device revision is 16
                                      [ 1.847770] Bluetooth: hci0: Secure boot is enabled
                                      [ 1.847770] Bluetooth: hci0: OTP lock is enabled
                                      [ 1.847771] Bluetooth: hci0: API lock is enabled
                                      [ 1.847771] Bluetooth: hci0: Debug lock is disabled
                                      [ 1.847772] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
                                      [ 1.857202] Bluetooth: hci0: Found device firmware: intel/ibt-12-16.sfi
                                      [ 3.877037] Bluetooth: hci0: Reading Intel version information failed (-110)
                                      [ 3.877039] Bluetooth: hci0 command 0xfc05 tx timeout
                                      [ 17.272526] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                                      [ 17.272528] Bluetooth: BNEP filters: protocol multicast
                                      [ 17.272531] Bluetooth: BNEP socket layer initialized
                                        @maldorhan try running modprobe -r btusb ; modprobe btusb and report back. If the first command fails, try rmmod btusb ; modprobe btusb
                                        Maldorhan 2 Replies Last reply Reply Quote 0
                                        • Maldorhan
                                          @substring rebooting gave me another error, that is really weird : (without to change anything since last signature error)
                                          /sbin$ dmesg | grep Bluetooth
                                          [ 1.449567] Bluetooth: Core ver 2.21
                                          [ 1.449577] Bluetooth: HCI device and connection manager initialized
                                          [ 1.449580] Bluetooth: HCI socket layer initialized
                                          [ 1.449583] Bluetooth: L2CAP socket layer initialized
                                          [ 1.449591] Bluetooth: SCO socket layer initialized
                                          [ 1.463656] Bluetooth: HCI UART driver ver 2.3
                                          [ 1.463658] Bluetooth: HCI UART protocol H4 registered
                                          [ 1.463659] Bluetooth: HCI UART protocol BCSP registered
                                          [ 1.463659] Bluetooth: HCI UART protocol LL registered
                                          [ 1.463660] Bluetooth: HCI UART protocol ATH3K registered
                                          [ 1.463661] Bluetooth: HCI UART protocol Three-wire (H5) registered
                                          [ 1.463685] Bluetooth: HCI UART protocol Intel registered
                                          [ 1.463696] Bluetooth: HCI UART protocol BCM registered
                                          [ 1.463696] Bluetooth: HCI UART protocol QCA registered
                                          [ 3.941418] Bluetooth: hci0 command 0xfc05 tx timeout
                                          [ 3.941450] Bluetooth: hci0: Reading Intel version information failed (-110)
                                          [ 5.957541] Bluetooth: hci0 command 0xfc05 tx timeout
                                          [ 5.957547] Bluetooth: hci0: Reading Intel version information failed (-110)
                                          [ 23.468044] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                                          [ 23.468046] Bluetooth: BNEP filters: protocol multicast
                                          [ 23.468050] Bluetooth: BNEP socket layer initialized
                                          • Maldorhan
                                            modprobe -r btusb
                                            I can't seem to be able to run the modprobe command (command not found) (that's where my small Linux knowledge stops I guess)
