    Solved Recalbox 4.1- Can't copy roms although there is enough space
    recalbox 4.1 cant copy roms
    5610
    • Grimlock42G1
      Grimlock42G1 last edited by
      Hi,
      I just set up a new installation of Recalbox 4.1 on a 64GB sdcard. Everything works fine, but if I try to upload a hole romset via samba share (\RECALBOX\share), at some point the copying process stops, because there isn't enough free disk space. Nevertheless there are still 55GB of free diskspace. Uploading via webinterface also stops at some point. Any ideas?
      Thanks!
      Grimlock
      seic 1 Reply Last reply Reply Quote 0
      • seic
        seic @Grimlock42G1 last edited by seic
        @grimlock42g1
        Have the same problem with my 64GB card. First I trough the problem was because the sd card was formatted
        as exFAT. But it doesn't matter, with FAT formation it is the same.
        Running a RPI2 , when I also check the "Disk usage" in Recalbox, it give me just an N/A so I don't know it is broken.
        • nwildner
          nwildner last edited by nwildner
          @Grimlock42G1
          I do not meant to be rude but, are you sure that your sdcard isn't one of those cards that are "way to cheap" and show up as a 32Gb card, but actually have a real 2Gb space of real storage?
          http://www.gadgetvictims.com/2012/07/quickn-dirty-way-to-fix-fake-sd-card.html
          A friend of mine was victim of those cards years ago.
          @seic . Have you take a look at this SD card related table? Maybe your card is there, and is a known problematic one...
          https://elinux.org/RPi_SD_cards
          PT_BR Retrogaming on Telegram
          • seic
            seic @nwildner last edited by
            @nwildner
            Samsung Evo, is working for many months inside my Pi. Was full with over 40GB of ROMs with 4.1 unstable until yesterday.
            • seic
              seic last edited by
              Ok my card is working now. This time I haven't selected quick format.
              • Grimlock42G1
                @nwildner It is a Kingston sdcard and works fine in my smartfone. I solved the problem by using another sdcard. Seems like the pi3 doesn't like the kingston sdcard. Retropie does also have issues.
                thanks nonetheless!
                • newbie
                  newbie last edited by
                  I have the same problem
                  But...
                  Formating without the "quick format" didn't solved my problem...
