    4.1 PC Engine Pixel Perfect Issues
    Emulator Arcade/PC/Console
    4.1 engine pixel perfect
    5253
    • n0signal
      n0signal last edited by
      Since the 4.1 update I'm LOVING that I can put "Square Pixels" as an aspect ratio and with "pixel perfect" integer scaling enabled I easily get true 8/7 razor sharp pixels on SNES and NES as well as Megadrive and Mega CD stuff looking fine as they always have.
      However, with these settings and PC Engine system game now displays in a tiny box on screen. It's almost as if rather than an integer scaler the "pixel perfect" is literally just displaying native resolution! I can solve this by turning off integer scaling and leaving it on square pixels but it's not as sharp as I'd like.
      • chad-ballew
        chad-ballew last edited by
        I too am having this issue - the old settings were perfect for PCE
        • n0signal
          No ideas anyone? I guess in the meantime I'll just have to turn off pixel perfect whenever I play PC Engine. /shrug
          chad-ballew 1 Reply Last reply Reply Quote 0
          • chad-ballew
            chad-ballew @n0signal last edited by
            @n0signal yeah, that's what I've been doing - without integer scale it looks to be the same as "pixel perfect" was before 4.1...at least for me.
            • chad-ballew
              I can't believe this isn't an issue for anyone else?
                and if you set your ratio on auto ?
                I'm using this setting to allow each core to manage itself the ratio aspect, then I use integer scale option.
                • chad-ballew
                  chad-ballew @rockaddicted last edited by
                  @rockaddicted said in 4.1 PC Engine Pixel Perfect Issues:
                  Correct - "integer scale" is considerably smaller than it was on 4.0
                  Aspect is set to Auto as well, yes.
                    rockaddicted @chad-ballew last edited by
                    @chad-ballew what kind of screen are you using ?
                    • chad-ballew
                      1080p LED TV 55"
