    [SOFT] GameList Editor
    Community projects
    [soft] gamelist editor
    31
    186
    126666
      voljega Banned @NeeeeB last edited by
      @neeeeb I don't know if this is in the feature list as this isn't mentioned but it would be cool if the tool would be able to detect "orphan" gamelist entries (with no corresponding existing game) and propose to delete them
      NeeeeB 1 Reply Last reply Reply Quote 0
      • NeeeeB
        NeeeeB @voljega last edited by
        @voljega
        You mean, the game is in the gamelist but not "physically" in the folder ?
        If so, that should not be too difficult to implement, I may even be able to do this today.
        @gmgman
        I have a bit of free time at the moment, so I try to be as effective as possible with my app lol
        What do you mean by scroble btw ?
        Vieux geek ^^
        voljega gmgman 2 Replies Last reply Reply Quote 0
          @neeeeb said in [SOFT] GameList Editor:
          Yes exactly that
          • NeeeeB
            NeeeeB @voljega last edited by NeeeeB
            @voljega
            On peut causer français aussi lol
            Je vais voir ce que je peux faire, mais ça ne devrait pas poser de souci du tout.
            J'ajouterai ça dans les options "système".
            @gmgman
            Scraping is on the TODO list, but in a second time.
            I will add the possibility to scrape missing pictures, and also send to Screenscraper if you choose a picture from your drive 😉
            But that will come in a future version.
            Vieux geek ^^
              @neeeeb yep c'est pas compliqué 😉
              • gmgman
                gmgman @NeeeeB last edited by
                This post is deleted!
                • NeeeeB
                  @voljega
                  New version !!
                  Nouvelle version !!
                  Added option to delete orphan entries from the gamelist.xml
                  Located under "Actions - System - Delete orphan entries"
                  Updated Help to explain what it does.
                  Option pour supprimer les entrées orphelines du gamelist.xml
                  Située dans "Actions - Système - Supprimer les orphelins"
                  Fenêtre d'aide mise à jour pour expliquer ce que ça fait.
                  https://github.com/NeeeeB/GameList_Editor/releases/tag/v0.9.4-beta
                  Vieux geek ^^
                    @neeeeb eh beh c'est rapide ! je vais pas tester tout de suite par contre, je suis en train de coder un truc de mon côté...
                    • NeeeeB
                      @voljega
                      Disons que j'ai pas trop mal pensé le truc du début donc ajouter ce genre d'option est relativement facile.
                      J'ai ajouté également "orphelins" dans la liste des filtres, pour les visualiser facilement.
                      Vieux geek ^^
                      • dschidschi
                        dschidschi last edited by
                        I just registered an account to let you know that this is an awesome Gamelist Editor and to say thank you. I would happily support you translating it to german, but as I can see, the german option is already there (although it doesn't do anything for me, it stays english). Still, awesome job, thank you 🙂
                        • NeeeeB
                          NeeeeB @dschidschi last edited by NeeeeB
                          @dschidschi
                          Many thanks and you're welcome !
                          The german translation is complete, but I still haven't uploaded a new version with it (I'm waiting for the Italian translation to be complete).
                          Yes the button is already there, it's because I added it and forgot to hide it while waiting for the translation ahah.
                          Check the thread tomorrow or sunday, I should have uploaded a new version with German and Spanish (and maybe Italian) !!
                          Vieux geek ^^
                          keltac 1 Reply Last reply Reply Quote 0
                          • keltac
                            keltac @NeeeeB last edited by keltac
                            @neeeeb
                            Beau logiciel.
                            Y'a-t-il la possibilité de supprimer plusieurs rom en même temps ?
                            c'est à dire faire une sélection multiple , puis de cliquer sur supprimer ..
                            En fait, moi j'ai certaines gamelist qui contiennent la liste des jeux en double ... me demande pas pourquoi, j'en sais rien..
                            Exemple, ma gamelist snes fait 23446 lignes !! alors que j'ai environ 800 jeux..
                            Si on prend environ 14 lignes par jeux, je devrais avoir donc environ 11200 lignes ... mais j'ai le double..
                            J'ai vérifié dans la gamelist, et tout les jeux sont doublés..
                            Y'aurai-t-il pas moyen que tu intègres une fonction pour supprimer les doublons ?
                            Merci.
                            • NeeeeB
                              NeeeeB @keltac last edited by NeeeeB
                              @keltac
                              Nope, pas pour le moment en tout cas( suppression multiple ).
                              J'y ai pensé et me suis dit que cétait pas forcément une bonne idée (genre fausse manip), mais je peux éventuellement y re-regarder, là où ça me pose problème c'est que le click sur un jeu déclenche le chargement des infos et de l'image, du coup je sais pas comment gérer ça pour plusieurs jeux pour le moment (je sais pas si je suis clair mais moi je me comprend ahah).
                              Pour ton problème de jeux doublés, ça fait quoi dans GameList Editor du coup ?
                              Tu te retrouves avec 1600 jeux ?
                              Je note en tout cas je vais voir si je peux intégrer une option pour gérer ça 😉
                              En tout cas si tu comptes utiliser la fonction supprimer pour virer tes doublons, c'est pas le bon plan, parce que ça supprime vraiment le jeu, non seulement dans le gamelist, mais en vrai aussi...
                              Vieux geek ^^
                              keltac daminoutav 2 Replies Last reply Reply Quote 0
                              • keltac
                                @neeeeb
                                oui ... j'ai 1600 jeux sur ton soft...lol
                                et oui ... j'ai remarqué que cela supprimait le rom et l'image. . J'ai testé sur un petit volume.
                                Seule solution que j'ai trouvé, c'est faire une copie des roms et des images, faire ensuite les suppressions des doubles sur le dossier d'origine avec ton soft , puis étant donné que cela va effacer les roms et les images, je réintégre les copies que j'avais faite..
                                mais bon ... on verra peut-être plus tard ... parce que c'est long à faire ...
                                • NeeeeB
                                  @keltac
                                  J'ai mis un message d'avertissement pourtant que ça effaçait TOUT ^^ c'est bien pour ça que l'option n'est pas activée par défaut...(et c'est aussi pour ça que je suis pas chaud pour autoriser la multisélection pour supprimer, parce que si tu cliques sur le bouton par erreur aprés avoir avoir tout sélectionné, pfffffftttt, plus rien, et ça va pas dans la corbeille en plus...)
                                  Je vais regarder ce week-end ou lundi pour intégrer un truc pour te faciliter la tâche tkt, faut juste que je réfléchisse à comment intégrer ça proprement, me demande si je le ferais pas automatiquement au chargement des gamelist (moyennant l'activation d'une option bien entendu, pas par défaut).
                                  Vieux geek ^^
                                  • keltac
                                    @neeeeb
                                    J'ai vu évidemment l'avertissement, mais je voulais tester quand même, lol.
                                    J'ai rien perdu puisque je travaillais sur des copies.
                                    Merci en tout cas.
                                    • daminoutav
                                      daminoutav @NeeeeB last edited by
                                      @neeeeb Pour la suppression multiple pourquoi ne pas rajouter une colonne "Coche" afin d'en sélectionner plusieurs ?
                                      Si ce n'est pas possible, il serait éventuellement intéressant que lors d'une suppression la liste ne reviennent pas en haut, quand tu parcours la liste pour supprimer beaucoup de jeux ça peut être long du coup ^^
                                      • NeeeeB
                                        NeeeeB @daminoutav last edited by
                                        @daminoutav
                                        La colonne coche revient exactement au même que la multi sélection, donc ça ne sera pas ajouté.
                                        Je ne veux définitivement pas autoriser la suppression PHYSIQUE des jeux en masse.
                                        Si vraiment vous souhaitez supprimer vos roms par paquets, virez les directement dans le dossier et ensuite lancez GameList Editor et utilisez l'action "supprimer les orphelins".
                                        A la base je ne devais même pas ajouter cette option de suppression et je ne veux pas être "responsable" d'une mauvaise manip d'un user qui lui viderait totalement son dossier de rom. (Je le rappelle, cette suppression delete directement sans passer par la case corbeille).
                                        Pour ce qui est du retour en début de liste, en effet ça peut être génant, je vais corriger ça.
                                        Je n'y ai juste pas pensé et comme ça supprime le jeu, il n'est plus dans la liste, et elle est reconstruite donc difficile de le garder sélectionné...
                                        Pour régler le problème je vais mettre la sélection sur le jeu qui se trouve juste avant une fois la suppression effectuée 😉
                                        Vieux geek ^^
                                        daminoutav 1 Reply Last reply Reply Quote 0
                                        • daminoutav
                                          @neeeeb C'est ce que je pensais oui, garder un repère via le jeu précédent, au top merci 🙂
                                          Et je n'avais pas vu qu'on pouvait supprimer les orphelins, du coup problème réglé 😄
                                          • NeeeeB
                                            @dschidschi @keltac @daminoutav
                                            New release available !!
                                            Nouvelle version disponible !!
                                            Added removal of duplicates in the gamelist.
                                            Located under "Actions - System - Delete duplicates from gamelist"
                                            When the list is refreshed (after a game deletion) selected item is no more lost.
                                            Updated languages and added German and Spanish.
                                            Possibilité de supprimer les doublons dans le gamelist.
                                            Dispo dans "actions - système - supprimer les doublons dans le gamelist".
                                            Quand on supprime un jeu, on ne perd plus l'item sélectionné dans la liste.
                                            Mise à jour des langues et ajout Allemand et Espagnol.
                                            https://github.com/NeeeeB/GameList_Editor/releases/tag/v0.9.5-beta
                                            Vieux geek ^^
                                            100.2k
