    Snes buttons not working with a adapter?
    snes buttons adapter
    • wsamh
      wsamh last edited by
      I just got an adapter for my snes controller. But when I try to map the buttons. The down and right buttons are not registering. I've tried two controllers and get the same result. So I know it is not the controllers. Is anyone having the same problem and is there a way to fix this?
      • ivwshane
        ivwshane last edited by
        It is a known issue but I'm not sure if there is a fix for it. Based on what I've read it appears to be an issue with how the OS sees the adapter. I believe it sees only one device when the adapter is actually two devices (regardless if you have two controllers connected or not). I'm pretty sure it's just a matter of fixing a driver and I thought I read that a future release of recalbox will fix it.   The problem is that the author of recalbox got a new job and he doesn't seem to be as active with the project anymore, it sucks but it's understandable.
