    Pasar de Recalbox 4.1 inestable a 4.1 estable
    Recalbox general
    pasar recalbox 4.1 inestable estable
    • KeroIn8Bits
      KeroIn8Bits last edited by
      Me gustaría saber si sera posible actualizar de 4.1 inestable a la futura estable de 4.1 o por el contrario he de volver a 4.0.2.
      En Recalbox ahora mismo me pone "Available Update No Conectado" y en el archivo .emulationStation/es_settings.cfg tengo la linea "<string name="UpdateServer" value="recalbox.com" />"
      Debería cambiar algo de cara al futuro lanzamiento?
      • boxcarpilot
        boxcarpilot last edited by
        Ya hay fecha para 4.1?
        No veo ningun anuncio en ningun lado.
        Yo creo que mejor haces backup y mueves todo a un USB, y luego instalar 4.1 fresh.
        https://github.com/recalbox/recalbox-os/wiki/Use-an-external-usb-storage-device-on-recalbox-(EN)
          Substring @KeroIn8Bits last edited by
          @keroin8bits This setting you mentionned has nothing to do with the update process (but just the DNS we ping to check if the box is online).
          Update from unstable to stable will of course be possible 🙂
          boxcarpilot 1 Reply Last reply Reply Quote 0
          • boxcarpilot
            boxcarpilot @Substring last edited by
            @substring I know this is the Spanish forum, but I wanted to use this post to ask if we have any ETA for 4.1 stable? and I guess that version will need a fresh install right?
            Spanish:
            Se que este es el foro en espanol, pero queria usar este post para preguntarte, si tenemos alguna fecha para 4.1 estable, y me imagino que dicha version requerira una instalacion en limpio?
              Substring @boxcarpilot last edited by
              @boxcarpilot never any ETA, because everytime we think we're ready, things never go the way we want. It's almost over, but there is always something "missing"
