    [4.1.0 Unstable] Using 7TFT no HDMI image on TV (but I got sound)
    [4.1.0 unstable] 7tft hdmi got
    13549
    • Defiant
      Defiant last edited by
      Hi everyone!
      I'm using a RPi 3 with a 7'' TFT screen (this one: Element 14 7 Inches TFT Screen )
      Screen works perfectly, has a terrific image quality, sound output is flawless through audio jack.
      Problem is when I plug the HDMI cable I've been using before to the TV, when I turn the RPi on I just see a black screen on the TV, and the image comes from the 7'' TFT.
      Only thing I get from the TV is sound.
      What am I doing wrong?
      Can I configure config.txt to "autodetect" when I plug HDMI and switch between HDMI and 7TFT? Or is there any script available for that?
      Thanks a lot in advance.
      Here's a copy of my current config.txt
      uncomment if you get no picture on HDMI for a default "safe" mode
      hdmi_safe=1
      disable_overscan=1
      uncomment to force a specific HDMI mode (this will force VGA)
      #hdmi_group=1
      #hdmi_mode=1
      #comment to get jack audio
      hdmi_drive=2
      #config_hdmi_boost=0
      force hdmi while the tv can take time before sending the signal on the hdmi output
      hdmi_force_hotplug=1
      #uncomment for composite PAL
      sdtv_mode=2
      uncomment for lirc-rpi
      #dtoverlay=lirc-rpi
      if you plug your tv at the same time as your rpi and that the rpi switches from the hdmi or give a low resolution because tv had no enough time to initialize it
      boot_delay=3
      #uncomment if you don't want the rainbow at startup
      disable_splash=1
      Overclock
      gpu_mem_256=128
      gpu_mem_512=256
      gpu_mem_1024=512
      avoid_safe_mode=1
      kernel=zImage
      NOOBS Auto-generated Settings:
      #hdmi_force_hotplug=1
      overscan_scale=0
      max_usb_current=1
      lcd_rotate=2
      avoid_warnings=1
      dtparam=audio=on
      • Defiant
        UPDATE:
        Tried tvservice while the HDMI cable is plugged and it detects the TV, but just that.
        It won't let me try -m or -M commands.
        -s says this:
        /recalbox/share_init/system$ tvservice -s
        state 0x400000 [LCD], 800x480 @ 60.00Hz, progressive
        -n says this:
        /recalbox/share_init/system$ tvservice -n
        device_name=GSM-LG_TV
        -a says this:
        /recalbox/share_init/system$ tvservice -a
        PCM supported: Max channels: 2, Max samplerate: 192kHz, Max samplesize 24 bits.
        AC3 supported: Max channels: 6, Max samplerate: 48kHz, Max rate 640 kb/s.
          Substring @Defiant last edited by
          @defiant hi
          You're not the first one having troubles with a DSI screen. Such feeling that it gets drtected befire HDMI, therefore this screen is set as first. Have you tried tvserice -e "CEA 16 HDMI" ? You may have yo stoo ES first
          • Defiant
            @substring said in [4.1.0 Unstable] Using 7TFT no HDMI image on TV (but I got sound):
            I haven't, but I will right now.
            I just didn't know I had to use ""s and always got an error message, thanks for the tip.
            So... I just did.
            Turned off then on with CEA 16 HDMI
            Just got sound, no image. The TV detects it as 16:9 1080/60p so it gets the signal right, only there's no image.
            • Defiant
              UPDATE:
              Just to confirm the HDMI is working, I added "ignore_lcd=1" to config.txt
              Then I rebooted and as expected, I got image and sound from the TV, the RPi LCD is off now.
              • Defiant
                UPDATE 2:
                I used display_default_lcd=0 on the config.txt
                HDMI works fine on TV, no image on LCD screen. When rebooted without the HDMI cable plugged, still no image on LCD 😞
                  @defiant ok, i didn't think about those LCD options in the config.txt. I've been working on my side for some autoconfiguration stuff. I'm not really sure of the rule, but this is how i think it goes :
                  1. look for HDMI
                  2. if no HDMI, go composite
                  Period.
                  Now, how I solved that (to use a geekworm DPI screen which is very handy) :
                  1. default forces lcd
                  2. if my monitor (and for now, only my monitor) is found, disable lcd and turn on HDMI
                  This is all explained in the doc of raspverry : https://www.raspberrypi.org/documentation/configuration/config-txt/video.md + https://www.raspberrypi.org/documentation/configuration/config-txt/conditional.md
                  • Defiant
                    Alright!
                    Thanks for the info @Substring , I'll be doing some reading on these articles and as soon as I figure out a way to make this work with my config.txt I'll be posting the results here for future reference.
                      @defiant don't forget that recalbox sets 720p on emulators, so you should probably set config.videomode to default in recalbox.conf to avoid that. I have worked on a auto mode for the videomode, but it won't make it to 4.1 (despite it works just great)
                      Defiant 1 Reply Last reply Reply Quote 0
                      • Defiant
                        Defiant @Substring last edited by
                        @substring I already thought of that, so I set config.videomode to default.
                        Now, I'm still having trouble getting it to work. I'm a bit lost at this point.
                        I can't get it to pick HDMI over LCD if HDMI is connected 😕
                        • Defiant
                          Well, I got it to work but only partially.
                          I added this to the config.txt:
                          [EDID=GSM-LG_TV]
                          ignore_lcd=1
                          hdmi_group=2
                          hdmi_mode=82
                          [all]
                          Now when the HDMI from my TV is connected before boot, it will detect and prefer HDMI and it works fine, and if HDMI is not plugged in, the LCD will come up as usual.
                          Problem is it only works with my TV... How do I make that work for example if I take it to a friends house?
                            @defiant I'm stuck at the same step ... It only works in very few cases (i.e. known TVs). I couldn't find any way to make it generic
                            • Defiant
                              @substring I think the answer is finding a way to have it detect HDMI and if detected run ignore_lcd=1 and if not detected, don't run it or change it to ignore_lcd=0
                                @defiant indeed but there is no generic hdmi filter, unless we can put a * in the section name ... That's somethinh we should ask on the official pi forum
                                • Defiant
                                  @substring That's not entirely crazy! I'll test that and see how it goes when I come back from work.
                                  In the meantime, can you give me a link to the official Pi forum? Thanks!
                                    @defiant Yeah sure : https://www.raspberrypi.org/forums/
                                      While searching, I wonder if these may be of interest :
                                      https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=193430
                                      • Defiant
                                        Ok I confirm [EDID=*] doesn't work.
                                        I hope I just got the syntax wrong, or there's something similar.
                                          @defiant You need to dig in the rasp forum ...
                                          • Defiant
                                            @substring Well I tried and I don't seem to find a complete answer...
                                            I found this article on PINN. I'm not using it, but can this be "adapted" to use on Recalbox???
                                            link text
