    Make ES forget all controllers
    GamePad/GPIO/USB encoder
    forget
    2411
    • boxcarpilot
      boxcarpilot last edited by boxcarpilot
      Hello team.
      (version 4.0.0)
      I am having a hard time with my controllers, I think I need to start fresh, my ES says 6 devices.. and I only have 2 controllers.
      Looking for a way to make ES forget about all those 6 devices , and configure just two... a SNES pad and an x360 pad-
      see:
      https://imgur.com/a/ttTZM
      Right before selecting configure a new controller, it says 6 devices detected.
      Thanks
        Substring @boxcarpilot last edited by
        @boxcarpilot what else is plugged to your pi ?
        • boxcarpilot
          at this moment Nothing.
          I just want to be able to use
          -An 8bitdo
          -and an arcade stick
          They work fine.
          • boxcarpilot
            I see what you are asking... I think this is the same issue I´m having:
            https://github.com/Aloshi/EmulationStation/issues/468
            So... I only have one USB port used at he moment:
            https://imgur.com/a/bHokk
            This is connected:
            https://imgur.com/a/pxkR5
            That´s it, but ES sees controllers from #0 to #5:
            https://imgur.com/a/Ub9j8 - https://imgur.com/a/6xcLM
            Detecting 6 game-pads
            https://imgur.com/a/679UD
              voljega Banned @boxcarpilot last edited by
              @boxcarpilot looks like you just activated the xboxdriver in recalbox.conf and specified 4 or 5 controllers I would say. Just modify the number of xbox controllers line to 1 in recalbox.conf if it bothers you
              boxcarpilot 1 Reply Last reply Reply Quote 1
              • boxcarpilot
                boxcarpilot @voljega last edited by
                @voljega you were right sir!, resolved, we can mark this as close.
                thanks all!
