    Need script help for Retroflag NESPi soft power switch hack
    GamePad/GPIO/USB encoder
    need script help retroflag nespi
    5037
    • Dan Zettinger
      Dan Zettinger last edited by
      I modified the retroflag NESPi case with the guide by James White to add a software shutdown switch however the script in the guide is for retropie and I have no experience converting this script to work with recalbox.
      Here is the guide for reference: https://drive.google.com/file/d/0B9AzTQWe_cTFem1JS01HVU1GMDg/view
      The main item I need to work is the power button with the reset button being less important. Has anyone been able to get this working and if so would you share the script you used?
      Alternatively, would I be able to modify the existing 'rpi-pin56-power' script to change the pins?
      Thanks in advance
      lainbebop rocordeiro 3 Replies Last reply Reply Quote 0
      • lainbebop
        lainbebop @Dan Zettinger last edited by lainbebop
        @dan-zettinger there is already a script posted on this forum, have a look in the search bar ! Only for 4.1 !
        Edit : idon't find anymore the post 😞
        It was a script with short press = emulator quit, long press = shutdown
        By @supernature2k i think ?
        Edit2 : i found it !!
        HERE
        Bartop Metal Slug Home Made :)
        https://forum.recalbox.com/topic/7656/my-mini-bartop-metal-slug/
        • alvina35
          alvina35 last edited by
          I try to solve it so You have one GPIO set to high, that delivers 3,3V ... as long as this GPIO is setted high the mosfat delivers power. When does the GPIO not deliver power? Right... if the Pie is shut off!
          The cap will loose power and the mosfat output also closes.
          POWER cutoff
          press the power switch again
          the Cap colect power again = Switch should be as closed
          then Power to the Pi....
          • rocordeiro
            rocordeiro @Dan Zettinger last edited by
            @dan-zettinger
            • rocordeiro
              @dan-zettinger Hello, have you managed to make the code changes to work as in the retropie?
              • Rick Serrano
                Rick Serrano last edited by
                I know they released a new Nespi case + early April 2018 and has a working safe shutdown and safe reset buttons. They include instructions on how to setup the script. Wondering if anyone can port that over to recalbox, would be awesome.
                101.4k
