    Can't use FBA custom configuration
    Emulator Arcade/PC/Console
    cant fba
    3751
    • lcapone32
      lcapone32 last edited by
      Hi all. I'm trying to use a custom keys configuration for FBA. I've followed the instructions here: https://github.com/recalbox/recalbox-os/wiki/How-to-use-custom-config-for-emulators-(EN)
      But at the end my custom configuration is just not loaded. I've tried with all these configurations in recalbox.conf:
      fba_libretro.configfile=/recalbox/share/system/configs/retroarch/inputs/fba_custom.cfg
      fba-libretro.configfile=/recalbox/share/system/configs/retroarch/inputs/fba_custom.cfg
      fba.configfile=/recalbox/share/system/configs/retroarch/inputs/fba_custom.cfg
      retroarch.configfile=/recalbox/share/system/configs/retroarch/inputs/fba_custom.cfg
      neogeo.configfile=/recalbox/share/system/configs/retroarch/inputs/fba_custom.cfg
      But at the end, when I run it, this is what I can see in the logs:
      ['retroarch', '-L', '/usr/lib/libretro/fba_libretro.so', '--config', '/recalbox/share/system/configs/retroarch/retroarchcustom.cfg', '/recalbox/share/roms/fba_libretro/1942.zip']
      using the default configuration instead of mine.
      I'm using Recalbox 4.0.2 on Raspberry pi 2.
      What am I doing wrong?
      • lcapone32
        Anyone helping here? I guess it should be something trivial, but I haven't found the solution in the docs or searching in the forum.
          Substring @lcapone32 last edited by
          @lcapone32 lemme check
            It does work the way intended. Can you do a hastebin of your recalbox.conf please ? are you sure the file you're referencing do exist ?
            • lcapone32
              Sure!
              recalbox.conf
              https://hastebin.com/uxizififil.php
              /recalbox/share/system/configs/retroarch/inputs/fba_custom.cfg (with 666 permissions)
              https://hastebin.com/uhayulalaj.ini
                @lcapone32 looks like someone decided to go full keyboard lol
                Well, it does work. Regarding your case, there was a fba-libretro bug for a while as the expected configfile would not match the system name. But anyway, it should work for neogeo at least
                lcapone32 1 Reply Last reply Reply Quote 0
                • lcapone32
                  lcapone32 @Substring last edited by
                  @substring Thanks! I only want to use it for fba_libretro. The multiple system overrides in the config are only failed attempts to make it work. Do you know what version of Recalbox / fba_libretro fixes this bug?
                  • lcapone32
                    And... any trick I can do meanwhile? I have a cabinet with the buttons mapped to the keyboard, so I really need the keys configured to be able to play.
                      @lcapone32 we could consider a trick if you can force your "keyboard" (is it an encoder ?) To strictly follow the mame crappy mapping as seen on xarcade devices. This all depends on your experience with linux
                      • lcapone32
                        @substring But the cabinet uses Mame keys!
                        Mame works great with no need of a customization, it's fba_libretro who doesn't follow that mapping and uses the default retroarch keys.
                          @lcapone32 juste tell me : does neogeo work with a custom configfile ? Because it should.
                          Have you tried fbalibretro.configfile ?
                          • lcapone32
                            @Substring Ok, now I'm feeling very stupid. Yes, I had not tried using "fbalibretro", and it worked perfectly.
                            Thank you very much!
                              @lcapone32 you can't feel stupid as it wasn't working the right way, as i told you on my forst post in your topic. Take care once 4.1 is out, you'll have to switch back to fba_libretro
