    Solved Screen freeze on system settings
    settings
    5775
    • kaz69
      kaz69 last edited by
      I have recalbox 4.0.2 and when I try to access the system setting the screen freezes and I need to pull the plug on my pi3 so it will restart
      Any ideas?
      P.S can I upadate my recalbox with a pt or mac
      Cheerscomputer
      • abunille
        abunille @kaz69 last edited by abunille
        @kaz69
        Good Morning, how large is your sd card?
        How was your installation process (how did you format your sd card to fat32, installation with noobs or from https://github.com/recalbox/recalbox-os/releases)?
        kaz69 1 Reply Last reply Reply Quote 0
        • kaz69
          kaz69 @abunille last edited by
          @abunille
          Hi
          I have recalbox running off my microSD card which is 16gb and the card was already formatted with NOOB on when I bought it, so it was all ready to go and just needed the programs installed from the selection screen when I power on for the first time
          • kaz69
            Also I'm still new to Raspberry Pi and Recalbox
            • abunille
              @kaz69
              You could try to format your sd card on pc or mac to "fat32".
              Then download the 4.0.1 release from the link above.
              Unzip the file to your sd card and try again.
              There are also many tools to format to fat32, but i personal use windows terminal on pc. When you want, you can also try this:
              1. Open Command prompt with administrative privileges
              2. DISKPART
              3. LIST DISK (You need this to find the Disk # of your USB Drive. On most machines, it will be "Disk 1”)
              4. SELECT DISK 1
              5. CLEAN
              6. CREATE PARTITION PRIMARY
              7. SELECT PARTITION 1
              8. ACTIVE
              9. FORMAT FS=FAT32 QUICK
              10. ASSIGN
              11. EXIT
              12. Unzip the recalbox.zip file to the sd
              • kaz69
                @abunille
                Thanks, when you say ad card are you referring to the micro sd card that's with the Pi? Would this not lose my rasbian and OSMC?
                Or am I doing this on a separate SD Card?
                • abunille
                  @kaz69
                  You didnt wrote about rasbian and osmc before 😉
                  Try it on an seperate sd card (maybe your sd card with rasbian, osmc and recalbox has not enough diskspace, didnt tried that so far).
                  At least 8gb (for a recalbox single installation)
                  kaz69 2 Replies Last reply Reply Quote 0
                  • kaz69
                    @abunille
                    Thanks , I'll give that a try
                    • kaz69
                      kaz69 @abunille last edited by kaz69
                      @abunille
                      Got my sd card and already said it's Fat32 I unzipped the file and placed it on the ad card. Connected my sd card reader up to my pi and started up my pi again but doesn't show only the old rascal box 4.0.2 one does. I removed the micro Sd and reboot but nothing.
                      No sure what I'm doing
                        You can follow this video (windows only). English subtitles are available in youtube's options.
                        https://www.youtube.com/watch?v=hl59A3FTK-U
                        • abunille
                          @kaz69 said in Screen freeze on system settings:
                          @abunille
                          remove the already inserted sd card and switch to the new one (without adapter/reader).
                          • kaz69
                            @abunille
                            When you said sd card I was thinking you were saying the ones used for a camera but your meaning micro sd.
                            Cool I'll need to go shopping for a micro sd today
                            • kaz69
                              I didn't manage to get a micro SD today so I looked to wipe and reinstall NOOb on the original SD Card which has worked and I can access systems now, as it's upgraded to 4.1
                              Thanks for the info and help
