    The Seiken Den Setsu 3 Problem (3 player)
    Emulator Arcade/PC/Console
    seiken den setsu player
    3183
    • Zemus
      Zemus last edited by
      Hi! This is a very specific problem and i dont know how to solve it.
      First of all, i try to play Seiken den Setsu 3 (Secret of Mana 2) german patched with 3 player hack.
      In general it works on Windows with snes9x 1.54, so the file seems to be ok.
      On recalbox the default core is snex9x_next (snes9x 2010; v. 1.52) and only P1 and P2 can move.
      if i change the core the snes9x 2002 it works, but the screen looks blurry.
      After that, i installed retroarch on windows 10 and test it again with both cores + snes9x 2005.
      Ive got these results:
      • 2002 works with P3
      • 2005 works also with P3.
      • 2010 can't handle P3
      Is there a way to add the snes9x 2005 core to recalbox? Or an updated version of the snes9x core ?
      Thanks in advance!
        Substring @Zemus last edited by
        @zemus Of course you can add a core by yourself if you can compile it or download it 😉
        Zemus 1 Reply Last reply Reply Quote 0
        • Zemus
          Zemus @Substring last edited by
          @substring
          Thx for reply.
          Is there a site with compiled or experimental cores?
            @zemus well, probably http://buildbot.libretro.com/nightly/linux/armhf/latest/, but I can't tell for sure. I haven't tried them but a few ones + you'd be on your own to try/test/setup etc ...
            • Zemus
              @substring
              This Site is a BIG step in the right direction 😄
              Thank You!
              I will try it as soon as i can.
              • Zemus
                Just want to say that it works perfectly now!
                • got the snes9x2005 core from the site
                • add to corelist /usr/lib/libretro
                • add corename to es_systems.cfg
                Thanks again!
                  @zemus i'm glad you could mak it on your own 🙂 Take care, your es_systems.cfg will be erased on updates
                  • Zemus
                    @substring
                    Thx for the reminder. Is there a permanent solution for this? Some custom override file or something?
                      @zemus I can't recomment the other solution I know as you would not get the updates on that file ...
