    Recalbox Cabinet - 42inch LCD horizontal or vertical
    Your recalbox
    recalbox cabinet 42inch lcd horizontal
    2939
    • derchristoph
      derchristoph last edited by
      Hi! I've finally got all my parts for my arcade project together but I'm still uncertain if I should place the LCD (its a standard 42inch LCD with 16:9 ratio) vertical or horizontal. I've understand that it's highly depending which games I intend to play, I'll propably will play most of my NES games.
      I'm curios about your experience with screen positionings and aspect ratios. In tending to use the LCD vertical with a 4:3 ratio which should fill up the screen quite well.
      I've intendet to make a 2 player Cabinet, similar to the sleek look of the "Retro Space Cabinet" by Martijn Koch but adopted to the screen positoning. (http://www.martijnkoch.com/index.php?cat=dsgn&language=en&big=ar0#nogo)
      Any thoughts from you are highly welcome!
        voljega Banned @derchristoph last edited by
        @derchristoph You'll have a bigger picture horizontally there is absolutely no point positioning the screen vertically unless you plan on pleying mostly vertical arcade games (shoot em up, donkey kong, that kind of things)
        derchristoph 1 Reply Last reply Reply Quote 0
        • derchristoph
          derchristoph @voljega last edited by
          @voljega Thanks for your feedback!
          I'll probably switch to a smaller screen (since the 42inch screen would require a cabinet with min. 110cm / 43inch width) and stick to a horizontal setup.
            Substring @derchristoph last edited by
            @derchristoph unless you stream games from your PC (if you have a >GT600 GPU) with moonlight hahaha !!!
            • Dragu
              Dragu Banned last edited by
              With 42", at 320x240, pixels have +-3mm. Also no pleasure at short distance from the screen. 🙂
              • derchristoph
                Thanks guys. Yup, the 42 was'nt my first choice anymway so it'll be ditched for a 32 or even 27. I'll keep you posted on the progress...
