    Disable state and network interface LEDs
    disable state network interface leds
    2309
    • lhari84
      lhari84 last edited by
      Hi,
      Is it possible to disable all onboard-LEDs of Pi3? The continuous blinking on TV-stand is quite annoying for me...
      Maybe some shell command or config file entry to get rid of it?
      Would be fine if there is a solution, instead of pasting a tape on 🙂
      Many thanks in advance for your answers!
      Pi 4:
      Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
      Pi Zero 2W:
      GPi Case 2W, Recalbox 9.0
        voljega Banned @lhari84 last edited by
        @lhari84 get a box ?
          Substring @lhari84 last edited by
          @lhari84 Errrr ... you can eventually change the PWR and ACT leds behaviour (but it's rather complicated), but I know nothing regarding the LAN.
          My advice : put some black tape 😄
          lhari84 1 Reply Last reply Reply Quote 0
          • lhari84
            lhari84 @Substring last edited by
            @substring
            This is the answer I was afraid of 😄
            Ok, so the good old tape...
            Thank you!
            Pi 4:
            Pi Zero 2W:
              @lhari84 I do have other ideas, though i don't know the english for it ... What ladies put on their nails ? I hope your girlfriend/wife/life partner is gothic 😉
              • lhari84
                @substring
                Unfortunately she isn't gothic. But I prefer the tape anyway, I think it's easier to remove 😉
                @voljega
                I have the original Pi-box, because I like the design. As most other boxes (?) it has holes to show the state LEDs and also LAN port is not covered where the LEDs are placed.
                Pi 4:
                Pi Zero 2W:
