    Solved [Résolu] Dualshock PS3
    dualshock ps3
    • marn59
      marn59 last edited by
      Bonjour Retroboy, Tout d'abord merci pour ce projet que j'attendais depuis longtemps 😃 Je sais que plusieurs sujets existent déjà sur le forum mais je voudrais avoir un avis extérieur sur ma situation: Configuration: - Raspberry pi 1 - une Dualshock 3 - un dongle bluetooth Bus 003 Device 003: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode) La procédure de pairing semble fonctionner:
      # cat /root/controllers.log
      manette usb detectée
      Current Bluetooth master: 00:15:83:15:a3:10
      Setting master bd_addr to 00:15:83:15:a3:10
      Le système repère la connection:
      # dmesg
      [  119.357666] input: PLAYSTATION(R)3 Controller (60:38:0E:D4:6B:CA) as /devices/virtual/input/input2
      # ls /dev/input/
      event0  js0     mice
      Lorsque je test la manette:
      # jstest /dev/input/js0
      Driver version is 2.1.0.
      Joystick (PLAYSTATION(R)3 Controller (60:38:0E:D4:6B:CA)) has 29 axes (X, Y, Z, Rx, Ry, Rz, Throttle, Rudder, Wheel, Gas, Brake, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, (null), (null), (null), (null), (null), (null), (null), (null))
      and 17 buttons (Trigger, ThumbBtn, ThumbBtn2, TopBtn, TopBtn2, PinkieBtn, BaseBtn, BaseBtn2, BaseBtn3, BaseBtn4, BaseBtn5, BaseBtn6, BtnDead, BtnA, BtnB, BtnC, BtnX).
      Testing ... (interrupt to exit)
      Axes:  0:     0  1:     0  2:     0  3:     0  4:     0  5:     0  6:     0  7:     0  8:     0  9:     0 10:     0 11:     0 12:     0 13:     0 14:     0 15:     0 16:     0 17:     0 18:     0 19:     0 20:    Axes:  0:     0  1:     0  2:     0  3:     0  4:     0  5:     0  6:     0  7:     0  8:     0  9:     0 10:     0 11:     0 12:     0 13:     0 14:     0 15:     0 16:     0 17:     0 18:     0 19:     0 20:
      Axes:  0:     0  1:     0  2:     0  3:     0  4:     0  5:     0  6:     0  7:     0  8:     0  9:     0 10:     0 11:     0 12:     0 13:     0 14:     0 15:     0 16:     0 17:     0 18:     0 19:     0 20:    Axes:  0:     0  1:     0  2:     0  3:     0  4:-32767  5:     0  6:     0  7:     0  8:     0  9:     0 10:     0 11:     0 12:     0 13:     0 14:     0 15:     0 16:     0 17:     0 18:     0 19:     0 20:
      Axes:  0:     0  1:     0  2:     0  3:     0  4:-32767  5: 32767  6:     0  7:     0  8:     0  9:     0 10:     0 11:     0 12:     0 13:     0 14:     0 15:     0 16:     0 17:     0 18:     0 19:     0 20:    Axes:  0:     0  1:     0  2:     0  3:     0  4:-32767  5: 32767  6: 32767  7:     0  8:     0  9:     0 10:     0 11:     0 12:     0 13:     0 14:     0 15:     0 16:     0 17:     0 18:     0 19:     0 20:
      Axes:  0:     0  1:     0  2:     0  3:     0  4:-32767  5: 32767  6: 32767  7:     0  8:     0  9:     0 10:     0 11:     0 12:     0 13:     0 14:     0 15:     0 16:     0 17:     0 18:     0 19:     0 20:    Axes:  0:     0  1:     0  2:     0  3:     0  4:-32767  5: 32767  6: 32767  7:     0  8:     0  9:     0 10:     0 11:     0 12:     0 13:     0 14:     0 15:     0 16:     0 17:     0 18:     0 19:     0 20:
      Axes:  0:     0  1:     0  2:     0  3:     0  4:-32767  5: 32767  6: 32767  7:     0  8:     0  9:     0 10:     0 11:     0 12:     0 13:     0 14:     0 15:     0 16:     0 17:     0 18:     0 19:     0 20:    Axes:  0:     0  1:     0  2:     0  3:     0  4:-32767  5: 32767  6: 32767  7:     0  8:     0  9:     0 10:     0 11:     0 12:     0 13:     0 14:     0 15:     0 16:     0 17:     0 18:     0 19:     0 20:     0 21:     0 22:     0 23:     0 24:     0 25:     0 26:     0 27:     0 28:     0 Buttons:  0:off  1:off  2:off  3:off  4:off  5:off  6:off  7:off  8:off  9:off 10:off 11:off 12:off 13:off 14:off 15:off 16:off
      Les valeurs de jstest n'évolue lorsque je bouge la manette ou appuie sur les boutons lors du test. De plus lorsque j'essais de configurer la manette elle est bien détecté par le système mais rien ne se passe lorsque j'appuie sur les boutons donc je ne peux pas lancer la configuration. Sur Github j'ai lu que le driver avait été modifié
      Hum, i'm afraid the sixad driver modified for the compatibility of chinese clones is not working with your dualshocks.
      Que pensez vous de mon jstest ? ( "29 axes" me semble un peu beaucoup) Je voudrais savoir comment modifier les drivers de sixad ou enlever le patch pour les manettes chinoises et tester avec la dualshock 3 ? Merci et Bonne continuation
      • digitaLumberjack
        Salut Merci pour toutes ces infos ca aide. Je vais recompiler le système avec sixad non modifié et te filer le lien pour que tu puisse tester. Si t'as un peu de temps demain ?
        • joseph-cortes
          joseph-cortes last edited by
          Hi any solution to this, I'm having similar issues. Fixed in V3.2.5 ?
          • marn59
            Hi Joseph, I have solved my issue by changing my bluetooth dongle. I use a Belkin dongle and it works fine.
            $ lsusb
            Bus 003 Device 017: ID 050d:016a Belkin Components Bluetooth Mini Dongle
