    Gamesir G3s (2.4GHz gamepad)
    GamePad/GPIO/USB encoder
    gamesir g3s 2.4ghz gamepad
    • saulob
      saulob last edited by
      I'm looking for a good wireless gamepad, so I found that one Gamesir G3s, this gamepad have 2.4GHz and Bluetooth 4.0 Wireless
      I want to use it with the 2.4ghz connection. I know that the controller has one dongle for it.
      Does anyone know if it works on Recalbox? Any 2.4ghz will work?
      Thanks
        Substring @saulob last edited by
        @saulob Have you tried using the search function at least ?
        • saulob
          @Substring yes I did. I only found posts about the Wired Gamesir gamepad 😞
          Nothing about the 2.4ghz version.
