    8Bitdo SNES 30 Controllers Multiple issues
    GamePad/GPIO/USB encoder
    8bitdo snes multiple
    • rickharpoon
      rickharpoon last edited by
      Hi
      I have looked everywhere for some help with this issue I am having,
      I have a Bluetooth Dongle and I have connected 2 8bitdo SNES Controllers
      I also was able to put one under Player One and One under Player Two.
      Here is the issue
      After not using them for a bit they turn off to maintain battery life I assume,
      once I sit back down to use them again here are some issues I am having
      1. The main page is scrolling to the left constantly until I hit the button and it stops
      2. That doesn't happen and the controllers have both un-synced
      3. Sometimes only one controller will stay synced and the other will become unrecognizable
      4. Sometimes when they both stay synced after only leaving them for 30-60 minutes they decide that the Player 2 controller is now Player 1 and vice versa
      I have them plugged into charge in the the wall plug and these things happen
      I then plug them into the Pi USB port and they happen as well
      All in all when I have to forget the controllers restart the system and re-sync everything they start to work properly again and everything is good. But of course when I am done gaming and leave them for a while this all happens over and over and over again
      Any help would be appreciated
      Thanks
      100.7k
