    How check if the HDMI is plugged in Shell Script ?
    read config.txt
    • Israel Neves
      Israel Neves last edited by Israel Neves
        Substring @Israel Neves last edited by
        @israel-neves Check the tvservice command
        • Israel Neves
          i build a 3.5 tft with recalbox, the thing is, the tvservice -s with HDMI plugged and not, gives the same answer
          • Israel Neves
            Israel Neves last edited by acris
            Here the script that i want to run with S99custom
            #!/bin/bash
            IFS='  ' read -r -a array <<< "$(tvservice -s)"   # THIS LINE ! tvservice -s give the same answer with or without HDMI plug
            echo "${array[1]}"
            if [ "${array[1]}" == "0x12000a" ]; then
            	echo "Sem HDMI"
            	if [ "$(cat /boot/tela.txt)" == "hdmi" ]; then
            		echo "Sem HDMI e setado como HDMI, setando como LCD"
            		mount -o remount, rw /boot
            		cp /boot/configLcd.txt /boot/config.txt
            		echo "lcd" > /boot/tela.txt
            		sh ./recalbox/scripts/recalbox-save-overlay.sh
            		reboot
            	else
            		echo "Sem HDMI, tela setada como LCD"
            		start-stop-daemon -S -q -m -b -p /var/run/fbcp.pid --exec /usr/bin/fbcp -- -n
            	fi
            	else
            		echo "HDMI Conectado"
            		if [ "$(cat /boot/tela.txt)" == "lcd" ]; then
            		cp /boot/configHdmi.txt /boot/config.txt
            		echo "hdmi" > /boot/tela.txt
            		reboot
            		fi
            fi
            test -e "/recalbox/share/system/custom.sh" && /recalbox/share/system/custom.sh $1
