    Enable N64 Emu on Pi 1 B+?
    • smutja
      smutja last edited by
      How can i enable the N64 emulator on the old Pi (B+) ? As i could figure out everything ist already there.
      • ekstreme
        ekstreme last edited by
        It's there. You just need to add a rom to the share for it to show up. Also consider over clocking or it will be terrible
        • smutja
          Where do I find the right directory? If i connect through smb windows network, there isn´t an n64 folder.
          • aaroncastello123
            aaroncastello123 last edited by
            Share/roms/n64 or share/bios/roms/n64 i can't remember now, but what about to do copy+paste with the rom?   just insert the microSd in your pc and do it, it's easier than smb
            • neko
              neko last edited by
              Pi 1 does not support N64 if I remember correctly...
