    Retroarch Input config messed up
    retroarch input config messed
    • Florian Gruehn
      Florian Gruehn last edited by
      Hello,
      i completely messed up my retroarch input configuration. Is there a way to reset it?
        delete this file /recalbox/share/system/configs/retroarch/retroarchcustom.cfg
        • Florian Gruehn
          Florian Gruehn last edited by Florian Gruehn
          this did not work either, I still cannot enter retroarch menu.
          I am using a Xbox Controller.
          this is the retroarchcustom.cfg.origin:
          core_options_path = /recalbox/share/system/configs/retroarch/cores/retroarch-core-options.cfg
          system_directory = /recalbox/share/bios/
          config_save_on_exit = false
          video_threaded = true
          #aspect_ratio_index = "21"
          video_aspect_ratio_auto = true
          rewind_enable = false
          rewind_buffer_size = 10
          rewind_granularity = 2
          video_gpu_screenshot = true
          video_shader_enable = false
          video_smooth = true
          savestate_auto_save = false
          savestate_auto_load = false
          video_shader_dir = /recalbox/share_init/shaders/
          screenshot_directory = /recalbox/share/screenshots/
          savestate_directory = /recalbox/share/saves/
          savefile_directory = /recalbox/share/saves/
          extraction_directory = /recalbox/share/extractions/
          cheat_database_path = /recalbox/share_init/cheats/cht/
          cheat_settings_path = /recalbox/share/cheats/saves/
          fastforward_ratio = -1.0
          input_autodetect_enable = false
          joypad_autoconfig_dir = /recalbox/share/system/configs/retroarch/inputs/
          input_joypad_driver = "sdl2"
          input_player1_analog_dpad_mode = "1"
          input_player2_analog_dpad_mode = "1"
          input_player3_analog_dpad_mode = "1"
          input_player4_analog_dpad_mode = "1"
          input_enable_hotkey_btn = "16"
          input_enable_hotkey = "escape"
          input_exit_emulator = "escape"
          and my default input cfg:
          input_device = "PS3CONTROLLERNAME"
          input_driver = "udev"
          input_b_btn = "14"
          input_y_btn = "15"
          input_select_btn = "0"
          input_start_btn = "3"
          input_up_btn = "4"
          input_down_btn = "6"
          input_left_btn = "7"
          input_right_btn = "5"
          input_a_btn = "13"
          input_x_btn = "12"
          input_l_btn = "10"
          input_r_btn = "11"
          input_l2_btn = "8"
          input_r2_btn = "9"
          input_l3_btn = "1"
          input_r3_btn = "2"
          input_l_x_plus_axis = "+0"
          input_l_x_minus_axis = "-0"
          input_l_y_plus_axis = "+1"
          input_l_y_minus_axis = "-1"
          input_r_x_plus_axis = "+2"
          input_r_x_minus_axis = "-2"
          input_r_y_plus_axis = "+3"
          input_r_y_minus_axis = "-3"
          input_analog_dpad_mode = "1"
          input_menu_toggle_btn = "3"
          input_exit_emulator_btn = "0"
          input_load_state_btn = "12"
          input_save_state_btn = "15"
          input_state_slot_increase_btn = "5"
          input_state_slot_decrease_btn = "7"
          input_screenshot_btn = "8"
          input_hold_fast_forward_axis = "+2"
          input_rewind_axis = "-2"
          • Florian Gruehn
            Nevermind. Worked fine, thank you very much!!
