    [SCRIPT] SystemSorter
    Community projects
    [script] systemsorter
    16
    84
    29274
    • supernature2k
      supernature2k @voljega last edited by
      @voljega as @paradadf pointed out, there are differences between themes and roms folder names. There's a pb in your script with GameCube because of that.
      About new systems, they should be called like theme folders so you can prepare your ordering method. Worse would be you'll have to change a few names 😁
        voljega Banned @supernature2k last edited by
        @supernature2k I'm using es_systems.cfg so name should be based on the name tag in es_systems.cfg, not necessarily the themes name ?
        I do not have any x86 Recalbox so there is no way for me to know what the name of the x86-only systems is in es_systems.cfg
          Substring @voljega last edited by
          @voljega you can just download the .img and look inside 😄
          But anyway yes : es_sysyems.cfg is the source of everything
            voljega Banned @Substring last edited by
            @substring without having to install it ?
              @voljega of course, if you have a tool that can browse inside .img ! Or reolace the download link with root.tar.xz, easier.
                voljega Banned last edited by
                @azvarel @supernature2k
                script updated with future systems : https://github.com/Voljega/scripts4recalbox/tree/master/SystemSorter
                azvarel abunille supernature2k 3 Replies Last reply Reply Quote 2
                • azvarel
                  azvarel @voljega last edited by
                  @voljega very thanks! 😃
                  Zodian Theme | #SNESProject
                  • abunille
                    abunille @voljega last edited by
                    @voljega
                    Thank you. One thing to edit is gc:
                    gc=gamecube
                    • supernature2k
                      @voljega and add atari800 😁
                      But thanks, we are now ready for a long time!
                        voljega Banned @abunille last edited by
                        @abunille gamecube system name is gc in es_systems.cfg ? Or am I wrong ?
                        @supernature2k Didn't see atari800 in any list, but anyway i'll have to add amigacd32 sooner or later too
                        • abunille
                          @voljega
                          Its gamecube 🙂
                          <system>
                              <fullname>GameCube</fullname>
                              <name>gamecube</name>
                              <path>/recalbox/share/roms/gamecube</path>
                              <extension>.iso .ISO .gc .GC .gcz .GCZ .gcm .GCM</extension>
                              <command>python /usr/lib/python2.7/site-packages/configgen/emulatorlauncher.pyc %CONTROLLERSCONFIG% -system %SYSTEM% -rom %ROM% -emulator %EMULATOR% -core %CORE% -ratio %RATIO%</command>
                              <platform>gc</platform>
                              <theme>gc</theme>
                              <emulators/>
                            </system>
                            @abunille yep already corrected and pushed 😉
                              @supernature2k So are we speaking about official integration or something ?
                                @voljega sooner or later, yeah
                                But one small word: i think your script doesn't handle unlisted systems in your various arrays, you should consider consider a fallback
                                voljega 2 Replies Last reply Reply Quote 0
                                  @substring you mean user added systems in the es_systems.cfg ? Yeah it's possible it doesn't handle it, I will correct that
                                    @voljega no i mean systems we (or whoever) would add that you wouldn't be aware of
                                      @substring yeah that's what I meant to 😛 so I will correct it
                                        @substring said in [SCRIPT] SystemSorter:
                                        Fixed and pushed
                                        supernature2k 1 Reply Last reply Reply Quote 2
                                        • supernature2k
                                          @voljega thx for your work!
                                          • carlajiji
                                            carlajiji last edited by
                                            j'ai ajouté le mode Mi(x)ed
                                            100.2k
