    My Recalbox iCade
    Your recalbox
    icade
    3358
    • bigderill
      bigderill last edited by
      Leave here a sample of my project with Icade ipad, converted with a 10-inch TFT screen. The joystick is connected to the GPIO. I need to finish the furniture. ----------------------------------- Laissez ici un échantillon de mon projet avec Icade ipad, converti avec un écran TFT de 10 pouces. La manette est reliée à l'GPIO. Je dois finir les meubles. https://www.youtube.com/watch?v=J_YR9QFzrlc
      • reivaax
        reivaax last edited by
        it's really nice project ! 🙂   Good job 😃
        • bigderill
          Thank you. I'm running out of wood and then will come the vinyl. When the end makes a big 19 inch.
          • totos21
            totos21 last edited by
            nice project 🙂 I want to make the same but I don't find 10-inch TFT screen. where you find it? Could you please explain how you connect joystick and boutons to gpio ? just with cables or you must supply it? Thank you for your answer.
            • bigderill
              TFT is an old portable TV. The lever and buttons've connected using the method with GPIO
              • bigderill
                • digitaLumberjack
                  Hi, cool project 🙂 I see you're planning on doing some mods ! Impatient to see the result 🙂
