    (Resolved) Problem saving state on mame
    neo geo forever
    • brunlee
      brunlee last edited by
      Hello,   I'm a new user of your fantastic distro, however after instalation (pi2 - sd 8gb) i'm facing a problem with saves. Playing mame roms, when i try to save state (pressing hotkey + y) i get the message: the core does not support save states. Can anyone tell me what i'm missing??   Thank you in advance.
      • digitaLumberjack
        Hi, You're not missing anything, the save states are not supported by the mame core.
        • brunlee
          Ohhh thats a pitty. There are plans to implement it or depends on retroarchs development???
          • digitaLumberjack
            It depends on the retroarch dev, but i don't know if it will ever be integrated. Maybe with newer versions of mame 🙂
