    Change Console entries order
    console entries order
    • Jaylinx
      Jaylinx last edited by
      Hello, I tried to follow this wiki:
      https://github.com/recalbox/recalbox-os/wiki/Change-Console-entries-order-in-EmulationStation-(EN)
      I have to find "es_system.cfg"
      The problem is I only have this in my folder
      Did I miss something ?
      Thanks in advance.
      HapHzrd voljega 2 Replies Last reply Reply Quote 0
      • HapHzrd
        HapHzrd @Jaylinx last edited by
        I also have this question. I couldn't find a obvious file to change the order of the systems. Is it in a different location, perhaps?
          voljega Banned @Jaylinx last edited by
          @jaylinx @HapHzrd this is old and obsolete, you can use the script SystemOrder in my signature to achieve what you want, but it is a little bit obsolete (although on Pi3 at least it should be more or what ok)
          • abunille
            abunille @HapHzrd last edited by
            @haphzrd
            the wiki contains share_init and not share.
            You are in the wrong folder.
